non-model primer
non-model primer
Posted by Anonymous on Saturday, November 11, 2006 6:04 PM
modelling primers tend to be expensive.  The tamiya stuff is ~$10 for a smallish can, mr surfacer is even worse.  anyone have any experience in using non-modelling primer?  just regular big spraycan you get from home depot or something?  i picked out an enamel based primer but it left a slightly bumpy finish.  anyone know something that works better?  paying so much for such a small can of glorified laqcuer paint seems crazy.
    January 2003
Posted by Triarius on Saturday, November 11, 2006 9:13 PM
The pigments in hobby paints are sometimes ground more finely than say, automotive primer; and some hobby paints are formulated to form thinner coatings than paints intended for 1 to 1 scale objects. You may be able to find an automotive primer with similar characteristics.
Another thing  you can do is wet sand the coarser primer with fine grit—800 and finer. This can produce a very smooth surface.
Posted by Anonymous on Saturday, November 11, 2006 9:48 PM
i use the 0.96 can of wal mart stuff,then wet sand as stated above,it works fine,just a little more work,but a lot less cash
    October 2005
Posted by gulfstreamV on Saturday, November 11, 2006 10:37 PM
I sometimes use a automotive primer(comes in the quart container) and I find it best to strain or filter it after thinning and prior to putting it in your airbrush. It's really common practice when spraying paint of any kind, auto,industrial, home etc. to strain/filter out the paint so it's of uniform paticulates.     (man I sound smart sometimesLaugh [(-D]) HTH
Stay XX Thirsty, My Fellow Modelers.
Posted by Anonymous on Sunday, November 12, 2006 2:53 PM
I use the Walmart stuff too. I filter it, spray two light coats and buff it down with a coffee filter.
Posted by Anonymous on Wednesday, November 15, 2006 1:29 AM
If by Wal Mart stuff we're talking Krylon, then yeah, I use the stuff too. I use the white primer, makes the colors come out how I want them ^_^.
How I do it is a decant them into a jar and air brush it on.  Gotta clean the airbrush VERY VERY VERY well after this, since if not, it's a pain in the bum to get all the dried paint out.  I usually gotta let it soak for a couple of days in laquer paint thinner if I don't clean it that well.
Anyways, my techinque is a couple of light coats with the airbrush, let dry over night.  The next day (sometimes I even wait two!), I take a toothbrush and go over each piece.  Gives it a nice smooth finish.  Then, I do another coat, let dry a day or two, repeat.
Something I've come to notice on the stuff is that it don't adhere well on corners, it seems.  The stuff just chips right off, even if I just brush it with my finger.  That's why I do multiple coats, to make sure it sticks on the whole piece.
EDIT: Oh, and I forgot the most important part: safety!  Look, with Tamiya, MM, and other acrylic paints you can get away with paintin in your garage or by an open window.  NOT WITH THIS STUFF.  This stuff reeks, stays in the air for a long time, and hurts you.  Put on a mask for using this stuff.
    January 2003
Posted by Triarius on Wednesday, November 15, 2006 11:08 AM
Either you are spraying too dry, or there is a surface contaminant in those areas.
I recommend not decanting aerosol paint. I used to help develop the stuff for a living—all the components of  a can of aerosol paint are carefully matched to optimize paint performance, including the valve and spray head. You will generally get as good or better results, and probably better adhesion, spraying from the aerosol can, rather than decanting it.
Decanting is also unsafe. God help you if there is a source of ignition anywhere near. The propellant in most aerosol paints is propane or sometimes butane…Sign - Oops [#oops]BOOM!Dead [xx(]
Posted by Anonymous on Wednesday, November 15, 2006 6:45 PM
Triaus, the stuff always ruins models for me when I spray it from the can.  Even from two or three feet from the model and shaking the can for a good two minutes, it goes on two thick and fills panel lines.
    January 2003
Posted by Triarius on Thursday, November 16, 2006 9:57 AM
I feel your pain…
I just did an experiment: I sprayed a good quality automotive primer on a sheet of styrene and allowed it to cure. I then overcoated with Future. The original surface looked smooth as velvet, even under low powers of magnification. The Future brought out the surface "detail" Shock [:O] Sanding with 800 and 1000 grit smoothed the paint surface, but I was surprised at how much sanding it took, how much paint I was able to remove, and how thick the coating was.
Jhande may correct me, but I think most automotive primers are intended to be sanded.
The fact of the matter is that many aerosol paints are formulated to produce relatively thick paint films. When you decant one, you are probably only spraying the finest pigment particles, the others having settled rapidly, so you get a thinner coating.
Methinks some of us need to research a good, inexpensive primer that does not require the practice of decanting the material from the aerosol can. Someone pointed out that there are such things (I think Tamiya makes one.) but as usual, the price is a bit high for something that gets used in large quantities.
Unfortunately, I no longer have access to a paint lab, or I could do film thickness tests on people's suggestions. Sigh.
Posted by Anonymous on Thursday, November 16, 2006 11:48 AM
I always decant into a small jar using a straw with my booth's blower on high. I use Walmart brand primer from their ColorPlace line. It has finer particles than automotive primers. Part#20010 Equipment Gray Primer. Always filter everything that you blow thru your airbrush and spray very thin coats. You just want to barely cover the plastic.
