Tamiya paint reacts with styrofoam in my travel case
    January 2006
Posted by PatlaborUnit1 on Tuesday, November 14, 2006 6:25 PM
Hi Everyone
I use plastic tubs to move my models and until now have not noticed any problems:
The green soft foam I use to store and move my models on is reacting with the Tamiya paints on my motorcyles. It is creating a mild bubbling/frosting under the paint that is highly noticable on the super gloss finishes.  I have only seen this on my gloss coated bikes, not on my flat coated  Gundam or helicopter kits.    Has anyone else ever had this reaction between foam and acrylics?
Any ideas on how to prevent the reactions other than not using foam?
thanks
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
    January 2003
Posted by Triarius on Tuesday, November 14, 2006 8:16 PM
Could be a plasticizer in the foam out-gassing and softening the finish. Use a different packing material.
    February 2006
Posted by Wilbur Wright on Tuesday, November 14, 2006 9:23 PM
try placing 100% cotton tissue paper, (basic kleenex) perhaps between the foam and the model, any tissue residue will blow off easily. Its also cheap. Maybe it will work. I's be interested to know how long the foam was in contact with the model and under what conditions? Hot trunk...humid ???etc???
I just hate moving models!
    January 2006
Posted by PatlaborUnit1 on Wednesday, November 15, 2006 10:38 AM
thanks for the replies. The same post on the auto side of the forums suggests using flannel as a packing material, which sounds good to me.
The conditions are normally closed-top box (one of those plastic stacking storage jobs) and temps here are average 70-80 in the room it is in. Humidity is defintely a factor when the cases are opened and exposed to ambient air but ive not had any kind of humidty buildup inside the cases.
 I agree withthe plasticizer, souunds like this component in the foam is reacting with the acrylics.
thanks again, got some adapting to do to the box.
David
    May 2006
Posted by Storch on Wednesday, November 15, 2006 1:25 PM
If it's the same kind of foam I am thinking of, then it has to do with the foam formualtion itself.  I have a green-grey pick apart foam leftover from a case that I use when gluing things and I have noticed that it is highly reactive.  There is a lot more crazing on the Styrene bases I use than when I just stand them up to dry.
 I have also noticed it to be very reactive to organics.  If I get the glue too close when drying, the foam turns a biright green color and crumbles to dust.
 If you are using the same stuff, I would say your best bet would be to just head to the local fabric store and look in the back in the section for re-upholstoring chairs.  They generally sell foam cheap and in large quantities.
