My new Spray Booth in progress
Posted by Anonymous on Monday, November 27, 2006 7:54 AM
Saturday I woke up and decided I put of redoing my Spray booth long enough.  Not wanting to commit to a final design and speding more money to make one from Stainless Steel again, I decided to proof my design ideas with a unit that will work and I can play around with.  I decided to use that Foam Core board form Staples for the base construction.  It was laid out, cut out and hot glued together in less than 2 hours.  I am still playing around with the vents to focus the suction where I want it and with the right velocity.
I also did as a friend suggested and made my bench into a down draft table and permantly mounted my blower fan to exhaust fumes from my shop.  Works pretty well.
When done, I will provide plans for making this from 1/4" or 3/8" plywood on Ausfwerks, free of charge, complete with a measured drawing and materials list for those so inclined.
I also redid my mounting for my Regulator and moved my new compressor to the far corner of the basement and plumbed it in.  This water Trap is also a new addition and is worth every penny paid for it.  Works like a charm.
Hope this helps someone.  Doesn't look the best, but it works and in the end, it will be made from 304 stainless steel with a nice bead blast finish!!! :D  :D
    May 2003
Posted by styrene on Monday, November 27, 2006 11:34 AM
Ted,
Your downdraft booth looks pretty good, and it looks as though you've put some thought into it.  Having said that, I hope you don't mind a couple comments.
Typically, most downdraft booths use the entire lower surface as an exhaust area, rather than having a couple exhaust ports, as yours seems to have.  Since you already have what appears to be a plenum beneath your spray area, you might want to consider installing some perforated board or even a wire mesh in place of the solid surface you now have, and cover that with a paint pre-filter.  This will help even out your airflow and also ensure more complete vapor capture. (For comparison purposes, the Artograph downdraft uses 2 layers of paint prefilters over an activated carbon filter.)
Lastly, I don't know whether you've inserted your model just as a prop or not, but all painting on a downdraft booth should be accomplished directly on top of the booth surface.  Since downdrafts only require about half the airflow of a typical side- or back-drafted booth (50fpm vs. 80-100fpm), keeping your work close to the airflow ensures more complete vapor capture (Another good reason for converting your total lower surface area to have vent capability).
Hope this helps a little.  Keep up the good work!
Gip Winecoff
Posted by Anonymous on Monday, November 27, 2006 12:02 PM
Thanks Styrene.
 My original idea was for a perforated table to use for the vent.  However, the foam core board is almost impossible to drill, so I went with the vent idea.  In the final version, I will do as you mentioned and use a perforated metal sheet.
 As far as the second point, you taught me something and I will use this in the final version.
Thanks millions for your input.
Posted by MikeV on Monday, November 27, 2006 1:06 PM
Gip is the man!
How you doing my friend?
Good to see you putting your knowledge to good use on here again.
