Will spraying lacquer dullcoat on dried acrylic paint have adverse reaction?
Posted by djrost_2000 on Tuesday, November 28, 2006 7:28 PM
Is it ok to spray lacquer dullcoat on acrylic paint that has dried?
Thanks,
Dave
    May 2003
Posted by DrewH on Tuesday, November 28, 2006 10:08 PM
If the acrylic is completely cured, Yup! No problemBig Smile [:D] Just use light coats and build up the dullness slowly. Do it lots.
Take this plastic and model it!
Posted by djrost_2000 on Tuesday, November 28, 2006 10:44 PM
Drew, thanks for the reassurance.  I think I'll let the acrylic cure for 48 hours before applying dullcoat though.
Thank you,
Dave
Posted by MikeV on Tuesday, November 28, 2006 10:50 PM
Drew is right.
Keep the airbrush farther away and spray some "dust coats" of dullcoat on it.
After that dries you can spray a little heavier as the dullcoat you dusted on will protect the enamel.
With the high-quality acrylic flats out there I see no reason to use Dullcoat lacquer anymore personally.
