Air Compressor Pressure Question
    October 2004
Posted by jvolker on Thursday, November 30, 2006 6:08 PM
This place is just great for getting questions answered and for learning!  OK, my Badger Air Regulator and Water Trap arrived today from Dixie Art.  I hooked it up to my old Badger 180 (about 30 years old now) and it appears that the max pressure it will produce is about 10 pounds.  Now, I haven't tapped the joints with teflon yet but I really didn't sense any leaks.  I am wonder if that is enough pressure to work with.  My range would be 0 to 10, doesn't seem like much.  Any ideas?
    August 2005
Posted by eizzle on Friday, December 1, 2006 9:12 PM
You should be able to work with it, but I would also tape those joints to! You might not feel any leaks, but they might still be there. I would guess you will end up spraying at about 7 pr 8 psi, not much, but it will work for really fine lines and such!
Colin
 Homer Simpson for president!!!
    October 2004
Posted by jvolker on Saturday, December 2, 2006 4:09 PM
Would you suggest that I spring for a new compressor?  From what I have read I can use one from Wal-Mart or Harbor Freight and that a holding tank would be a good idea.  What is your thinking on that?
Posted by MikeV on Saturday, December 2, 2006 4:16 PM
If that gauge is correct 10 psi is too low, especially if you are using a siphon-feed airbrush.
I don't even go that low with a gravity-feed.
    August 2005
Posted by eizzle on Saturday, December 2, 2006 5:10 PM
Yeah, you can use those. Make sure the noise isn't going to bother anybody, they can be rather noisy!
Colin
    June 2006
Posted by MaxPower on Sunday, December 3, 2006 1:56 AM
A drop of windex or soapy water on each joint will tell you if you have a leak real fast!
    October 2004
Posted by jvolker on Sunday, December 3, 2006 5:23 PM
I just want to thank you guys for your help and good ideas.  I taped all the connections (to include the threads on the brush) and my pressure went up to a maximum of about 40 pounds!  I can control it from there all the way down to 1 or 2 pounds.  I am using my new Iwata HP-CS as soon as my Squadron order arrives with my paints and thinner.  Thanks for all the great help.
    March 2006
Posted by Shellback on Sunday, December 3, 2006 5:48 PM
Great ! A problem solved and a response from the happy customer , usually we dont get any feed back form our answers . Thanks for letting us know how the problem got solved  jvolker Thumbs Up [tup]
    August 2005
Posted by eizzle on Sunday, December 3, 2006 6:21 PM
Sign - Ditto [#ditto] Glad it worked out for ya!
Colin
