I stripped acrylic and enamel off a Verlinden 200mm figure recently.
I tried brake fluid and Simple Green, which both worked, although VERY slowly.
Getting impatient, I then used Castrol Super Clean which worked in no time, with a bit of scrubbing from a toothbrush.
No damage to the resin, though a couple of the CA-glued joints had to be re-glued.
Thanks
Neil
