Tamiya Paint Mixing?
Posted by IBuild148 on Monday, January 8, 2007 1:55 PM
I want to try my hand at airbrushing using Tamiya paints on my first armor (M10 Tank) kit but have a slight problem.
In the past I have used only Model Masters and the mix ration I use on my military planes is a 3 paint to 1 thinner for flat colors using the EXY Dose spoon dropper.
With Tamiya they give no direction on the mix ratios. I read somewhere to use a 50/50 mix.
I just tested a light coat of a 50/50 mix of XF-62 & X-20A on a Opel Blitz 3T 1/48 Resin kit I am building and it looks to runny.
Does anyone have successful ratios? Also can you clean your airbrush after using Tamiya Paints with water as suggested or is Mineral Spirts OK?
IBuildOne48
Teach modeling to youth!
Scalefinishes.com
http://i712.photobucket.com/albums/ww122/randysmodels/NMF%20Group%20build%20II/Group%20Badge/NMFIIGBbadgesmall.jpg
    April 2004
Posted by crockett on Monday, January 8, 2007 2:13 PM
You want the Tamiya acrylics to be about the same consistancy as skim milk. Tamiya acrylic thinner is the best, but expensive. I have great results using 91% isopropyl alchohol, with a tiny drop of dish detergent to keep the paint from drying in mid air. My ratio is one part thinner to 2 parts paint. Sprays through my Badger 360 and my Iwata Micron like a dream. Mineral spirits are a NO NO for acrylics.Thumbs Up [tup]
My M10, (AFV Club), finshed with Tamiya acrylics:
regards,
Steve
    February 2006
Posted by ruddratt on Monday, January 8, 2007 2:23 PM
After I've sprayed with Tamiya paints, I'll blast some windex through my airbrush first to clean out the majority, then I spray some lacquer thinner through just in case there are any stragglers.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    January 2003
Posted by Triarius on Monday, January 8, 2007 3:41 PM
Steve and Ruddratt have it pretty much covered. My ratios are close to 1:1—I usually start there. It varies a little with relative humidity. I always use 91% isopropyl for thinning. Windex or Simple Green or "Magic" (1 part Windex, 1 part Simple Green, 2 parts water) for cleaning.
The only time I exposed Tamiya to lacquer thinner, I got a coagulated mess that was very difficult to clean up—but lacquer thinners vary. Those with a high alcohol content might do well, indeed, especially as a final rinse. Those heavy on other organic solvents might not. I'd test your brand, first.
Posted by IBuild148 on Tuesday, January 9, 2007 5:00 PM
Steve,
Thank you very much on the Tamiya mixing instructions. IT WORKED perfectly.
Now can I ask you of something else? Since this is my first armor kit and an M10 by the way I would like to pick your brain as I asemble and paint. I am very impressed with your M10 and see you are very advanced.
 I'll wait for your response before I send my first question.
 Thanks,
 Marc
IBuildOne48
Scalefinishes.com
Posted by IBuild148 on Tuesday, January 9, 2007 8:16 PM
Thanks for the help and advice.
IBuildOne48
Scalefinishes.com
