Absolute cheapest compressor recomendations?
    August 2006
Posted by IanIsBored2000 on Tuesday, January 9, 2007 8:34 PM
Well, I got an aztek a270 airbrush for christmans, and since its a beginer set, it came with a 6oz testors propellant can to power it.  I used it all up, and found out that a new 6oz can costs about 12 dollars, so I figured I might as well buy a compressor, since over time those cans will ad dup anyways, plus they get too cold to use after about a minute and arent very consistant.  So, Im looking for a really really cheap compresor.  It doesnt need to have anything fancy, doesnt have tobe perfectly consistent or anything, just something easy, preferably a bit quiet, and small.  Any suggestions?  Im willing to all ideas as long as it doesnt cost much.  Als, I love ebay so if anyone has specific items to point out on that site feel free.  Thanks, Ian.
"Scanlon: work your knobby hands on the table in front of you, constructing a make-beleive bomb to blow up a make-beleive world."
    May 2005
Posted by Bgrigg on Tuesday, January 9, 2007 9:16 PM
There are ones that are cheaper, but they're likely going to be crap.
This is the cheapest I'll recommend:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92403
Another idea is to use a tank you can refill at a gas station, should be enough for one model between refills:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41712
Don't Ebay, so you'll have to search that by yourself! Wink [;)]
So long folks!
    August 2006
Posted by IanIsBored2000 on Tuesday, January 9, 2007 9:27 PM
thanks, I saw that same one on ebay for about 70 after shipping.  I was hoping to go a bit lower, but if thats the cost I guess thats still pretty good.  Any other suggestions?
    August 2006
Posted by IanIsBored2000 on Tuesday, January 9, 2007 9:30 PM
Just found the same one AGAIN in a tool catalog my dad gets for around $50.  Thanks for the help.
    January 2003
Posted by Triarius on Tuesday, January 9, 2007 10:00 PM
Check out PEP Boys—they recently had a compressor with tank, auto on and off, (on at 40 psi, off at  100 psi), with usable but not great regulator for ~$60.
    December 2004
Posted by Hippy-Ed on Wednesday, January 10, 2007 6:40 AM
I have one very similar to this one which I've had for the past 2 & 1/2 yrs or so now. i believe this one has the adjustable air regulator already installed. Not very loud & runs my Badger 175 quite well.  You'll find them on sale often in the store several times a year.
Eddie
If you lose your sense of humor, you've lost everything
Posted by kp80 on Friday, January 12, 2007 12:23 PM
I bought a Campbell-Hausfeld in WalMart for $69.  It has a built-in pressure regulator, and has a low pressure cut-in of 75 psi, and high pressure cutout of 100 psi.  It is oil-less and is mounted on a 2 gallon storage tank.  The compressor is noisy (but not intolerable, by my standards).   It's been working fine for my airbrush usage.  The only accessory I added was a moisture trap.
jwb
    February 2006
Posted by jwb on Friday, January 12, 2007 1:49 PM
"Absolute cheapest compressor recomendations?"
Step one: Attach hose to airbrush
Step two: Insert other end of hose in mouth
Step three: Blow vigourously until the model is painted or you pass out
Wink [;)] LOL
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
    May 2005
Posted by Bgrigg on Friday, January 12, 2007 5:02 PM
Wink [;)] LOL
Campbell-Hausfield "garage" compressor: $69
Paasche D500: $107
Silentaire DR500: $629
Image of Jon passed out after spit painting a B-29: Priceless!
So long folks!
    December 2004
Posted by Hippy-Ed on Friday, January 12, 2007 6:00 PM
Wink [;)] LOL
Paasche D500: $107
Sign - Ditto [#ditto]Sign - With Stupid [#wstupid]Laugh [(-D]Laugh [(-D]
    January 2005
Posted by jinithith2 on Friday, January 12, 2007 10:00 PM
If you wanna get excrement for your moneym buy the Mighty Mini. It's so mighty, that it makes my airbrush spit paint at mid position (Aztek dbl action, mid air, mid paint, did make sure that paint was thinned properly).
for 50 bucks, you get a lot. an A270 (I understand that you have that already though), some paint and the Mighty Mini, not to mention a pair of blown out ears.that thing sounds like it can grind coffee, possibly rocks. Oh yeah, it does work with badger brushes, with or w/o the adapter/regulator fitting. w/o, then you will experience unimaginable shock in the middle of your painting session because when the compressor heats up, the mount for the hose will expand causing the hose to come shooting out.
in other words, I'd go with something else Big Smile [:D]
hey, does anyone know if the 5gallon tank mentioned above can fit aztek brushes? it's silent, and where I am going this summer for the next four years, silence is golden.
    May 2005
Posted by Bgrigg on Friday, January 12, 2007 11:21 PM
Jin,
The tank comes with a 1/2" NPT fitting, you should be able to get an adapter to fit any airbrush.
So long folks!
    June 2006
Posted by Air Master Modeler on Saturday, January 13, 2007 12:58 AM
The Campbell Hausfield is about the cheapest you can get and still get a quality air compressor. It does work well with just about any DA or SA airbrush. Here in Okieville our Wal Marts sell them for around $50.00.
Air Master
Rand
30 years experience building plastic models.
WIP: Revell F-14B Tomcat, backdating to F-14A VF-32 1989 Gulf Of Sidra MiG-23 Killer "Gypsy 207".
Posted by MikeV on Sunday, January 14, 2007 2:01 PM
Air Master
I would recommend putting a fan near them to keep them cool as they have a tendency to die young when worked very hard.
Posted by Anonymous on Monday, January 15, 2007 5:41 AM
Wow, everyone is worried about noise lol. I believe I use a industrial 4 gal. 2hp compressor lol, it is loud for a min. but then with the regulator, it can do a whole model without recharging.
Guess what! I can do car tires and airguns with it too!
Noise they say....;)
    December 2004
Posted by Hippy-Ed on Monday, January 15, 2007 11:08 AM
Sacriledge I say!!Grumpy [|(]
    February 2016
Posted by alumni72 on Monday, January 15, 2007 11:36 AM
Before I semi-retired in 1991, I had a Badger airbrush and tried using the cans of propellant.  They gave poor results and cost a lot, so I decided to do what someone (forget who) recommended - I hooked my airbrush up to an old spare tire that didn't have enough tread any more.  I never got a chance to use it, so I don't have any idea how well it would have worked.  But it sure was cheaper than buying a compressor - and at the time the cheapest I could find was around $120.
    January 2005
Posted by jinithith2 on Monday, January 15, 2007 9:24 PM
is that airtank above regulatable?
    August 2006
Posted by IanIsBored2000 on Wednesday, January 17, 2007 3:44 PM
Haha, I dont think Im quite cheap enough to resort to using flat tires, and Im DEFINATELY not blowing on the end of it!  But thanks for all the suggestions, theyve been very helpful.  Im going to do a bit of looking locally since shipping cost could be high.  Thanks guys!
Posted by m1garand on Thursday, January 18, 2007 8:12 AM
I did use the spare tire to use my badger airbrush as well back in the days (well, I was only 13 at that time) and it worked pretty well.  Only problem was that I never had enough air to finish a model before the refill.  I read an article in one of the modeling magazines in Korea that some people build their own air compressors by using old refridgerators' compressors.  Again, this was a common practice in some parts of the world due to pricing/availability of modeling tools.
    August 2006
Posted by IanIsBored2000 on Thursday, January 18, 2007 6:10 PM
Seriously? I thought it was a joke.  The image I get is just too funny.  I'd give it a try, but my dad wants a compressor for something or other anyways, so I guess Im gettting a real one.
    December 2004
Posted by Hippy-Ed on Thursday, January 18, 2007 7:12 PM
That's cool. I got my Harbor Freight Hobby air compressor and, a twin tank Contractor's Grade air compressor for my air tools
    January 2005
Posted by jinithith2 on Thursday, January 18, 2007 9:13 PM
when I'm feeling blue... it's time to halt my airbrushing session for a while and go take a breath
