Problem with Badger 200 Airbrush
    January 2003
Posted by emo07 on Friday, January 12, 2007 9:57 AM
Hi all,
I have a Badger 200 single action airbrush that I have used for about the last 6 years. Until now, it has worked well.Yesterday, I was using it and it would spray in pulses, not a steady flow while button is depressed. If I remove paint bottle and spray just air, it works fine! ! have fully dissassembled and cleaned everthing. Whats wrong! Please help,
Thanks,
emo07
" When I saw fighters escorting the bombers over Berlin, I knew the jig was up." - Herman Goering
    May 2006
Posted by waste gate on Friday, January 12, 2007 11:36 AM
I had the same problem w/ my 200 about 8 months ago.  I went to my LHS and purchased a Badger item # 50-036  http://dixieart.com/Parts_for_Badger_Model_200SG_200G.html .
 Everything works great now.  I hope its helpful.
 waste gate
P.S. I thought it easier to purchase the entire assembly than the individual pieces.
    June 2005
Posted by MontanaCowboy on Friday, January 12, 2007 10:19 PM
Most likely a busted needle bearing. You can't replace these on your own, send it in to badger. My 200 had the same problem, I tried replacing the valve assembly above, now I have an extra air valve laying around. Send it in.
Mine had the same problems, sent it in, and now it works like new. And they cleaned it. For FREE!!
Just pay shipping to them.
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly." No wait, that's not it.
    January 2004
Posted by MusicCity on Saturday, January 13, 2007 7:02 AM
Two things ....
First, the old-style Badger 200 has a Teflon washer between the head and body, Badger part number 50-055.  Over time that washer will flatten and cause pulsation in the spray.  It's a common problem with an easy fix, just replace that washer.
Second, completely disassemble the airbrush, remove the air valve, and soak everything EXCEPT the air valve in lacquer thinner overnight.  Also clean the top of the bottle cap assembly with a pipe cleaner soaked with lacquer thinner.  You may think it's clean but it isn't.  It has some dried paint in it.
    January 2003
Posted by emo07 on Saturday, January 13, 2007 10:17 AM
Thanks Waste Gate, Montana Cowboy, and Scott. I will try your suggestions.
Thanks again,
emo07
