Working with Acrylic paints
    February 2006
Posted by PALADIN on Monday, January 15, 2007 4:23 PM
Hello out there,
 I have just recently rekindled my past hobby from many years ago and boy are things different now as to quality and all the ins and outs, dos and dont's, etc. I read all that I could about using acrylics as opposed to enamels. I went with acrylics due to clean up and odor. I have found though that it is really tough trying to use Tamiya acrylics using a brush. I get poor coverage and when working with smaller items such as flesh colors on a pilot etc., it just seems globby. I have found that the acrylics spray well, but maybe it is just inexperience on my part but brushing with acrylics I'm flopping. Are there any tips or directions that would help me here or is it just better to stick with enamels when brushing?
 Thanks
    August 2005
Posted by Phil_H on Monday, January 15, 2007 5:39 PM
Once upon a time, Tamiya's acrylics had nearly magical properties.
Straight out of the bottle, they went on incredibly smoothly, levelled themselves out, and with the right brush looked almost like a sprayed finish..... Then they changed the formula...  Banged Head [banghead] Dead [xx(]
Since the early 90's, Tamiya's acrylics are notorious for "roll-up" because it starts to "skin over" super-fast. Brushing back over paint that you have laid down - even just a few brush strokes earlier, will drag up the previously laid down paint.
For best results brush-painting with "today's" Tamiya acrylics, you need to add a little thinner and acrylic retarder - don't paint straight out of the bottle.
Transfer some paint to a pallette and then add a little thinner - how much is really a matter of experimentation. When you have the right consistency, squeeze a single drop of acrylic retarder onto your pallette (not into your paint/thinner mix) and when painting, just touch the tip of the brush to your drop of retarder before "loading" your brush.
It may seem fiddly, but the results are worth it.
Posted by gjek on Monday, January 15, 2007 10:04 PM
Tamiya's acrylics spray on well. Go with another brand if you plan on brushing. Technically there are things you can do to make it easier to brush on such as adding retarders etc... but it might be easier to just use another brand. Some like Model Master others like Polly S. You might try buying a bottle of several brands and test which one behaives best for you. Greg
Msgt USMC Ret M48, M60A1, M1A1
    January 2003
Posted by Triarius on Monday, January 15, 2007 10:43 PM
I brush Tamiya on small parts frequently. The trick is to keep a small container of 90% isopropyl handy. Dip the brush in the alcohol, then in the paint (in a small container, not the bottle). Then apply the paint. Using retarder is a great idea for larger areas or parts.
    February 2006
Posted by PALADIN on Tuesday, January 16, 2007 4:36 AM
All very helpful tips as I knew they would be. I can only imagine what a master modeler I could have been if all those years ago there was this avenue available and I had kept up with what was truly a passion in my youth. Now it has become a work in process to catch up, but am enjoying the challenges. Thanks for the information.
