Karl,
To answer your question: If the face size of your booth is 18" X 18", then you'll need a fan that will provide about 225 cfm. If the face size is 18" X 24", then approximately 300cfm is what you'll need. Those are fans that will provide a face velocity of 100fpm, which will ensure good vapor capture. Depending on the length and diameter of your duct work, you might consider increasing your cfm ratings by about 25%. These are figures for a back drafted booth.
If you are in the mood for a downdraft booth (a much more efficient setup, IMHO), you can cut your velocity requirements in half.
If you're looking for a commercial booth (ie, one you don't have to build yourself), trawl a bit farther and look at both the Artograph downdraft, or the one sold by Micromark. Paasche has a good selection of back drafted booths, as well.
Stay away from kitchen and range hood fans. They're the wrong fan, period. While they may work, you do NOT want to introduce any new potential hazards into your modeling setup.
Lastly, research this forum. This question has been addressed previously in numerous postings.
Hope this helps.
Gip Winecoff
