Acrylic vs Enamel...thoughts on the topic?
    January 2007
Posted by bcamp1973 on Monday, January 22, 2007 12:26 AM
I'm curious what people choose acrylic paints over enamel paints or vis versa? Is one better than the other for specific applications or is it merely a personal taste thing? I'm thinking that going one route or the other would be better than having to buy thinners etc. for both on an ongoing basis. Just curious what your experiences tell you...
Cheers,
Brian “When it's all said and done, you just rented the stuff anyway” Just finished : Tamiya 1/48 F-4U Corsair In progress : Tamiya 1/24 Mercedes SLR McLaren Next up : AMT Jupiter II
Posted by RonUSMC on Monday, January 22, 2007 3:05 AM
When I got back into the hobby I went all out on Acrylics. I used to do enamels, but based on a few things I decided to go Acrylic this time around and I am not sorry at all.
They dry faster. When airbrushing it dries almost instantly... prevents dust
easy clean up... water or windex
slight smell.. nothing like enamels which is crazy
I can use water to clean my brushes... which is where i generally use most of the thinner. its great to be able to dump out dirty brush cleaner and get new stuff from the faucet.
 I do have a few cans of enamels though.. so i use them for primer on models. It has a nice bite to it and its great for priming.
http://finescalegallery.com Active Kits: 1/48 AM Avenger 1/35 Sd.Kfz 251 Ausf C
Posted by waikong on Monday, January 22, 2007 12:37 PM
Another vote for acrylic, for the same reasons Ron mentions. The fumes from enamels and its thinners is just overpowering.  Enamels does spray easier with an airbrush, but with the right technique, Acrylics works almost as well.
    August 2003
Posted by bilbirk on Monday, January 22, 2007 11:40 PM
Enamels for me! I don't have very good luck with the acrylics and as for the smell? what smell?
    August 2005
Posted by EdGrune on Tuesday, January 23, 2007 8:05 AM
I too prefer enamels.   I do not find them to smell particularly offensive.   Enamels, particularly flats, dry quite fast.  Dust is not an issue.  I am able to spray and unmask almost right away.
I use inexpensive hardware store thinners without being tied to the often expensive model paint company's proprietary thinner for their brand of acrylics.  (How many have had you acrylic paints turn to goo in the paint cup when you added the wrong thinner?)
Additionally the sole source of accurate, out-of-the-bottle colors for my prefered modeling genre' (ships) is enamels - White Ensign's Colourcoat line of paints.  These colors are not available in acrylics.
Bottom line is use what works best for your particular application and modeling style.
Posted by waikong on Tuesday, January 23, 2007 8:14 AM
With either one you choose, please use proper caution. Especially with enamel, I'm less worried about the smell than what that smell is. The thinners used with enamel paint are very harmful to your lungs, I think both ventilation and masks with organic filters are a requirement when working with enamels.
jwb
    February 2006
Posted by jwb on Tuesday, January 23, 2007 5:40 PM
I've been really happy with Polly Scale. Water soluble... did I spell that right? Anyway.... water dissolvable Wink [;)], no smell, easy clean up, good coverage, lays down well when brushed on.
Plus it leaves your breath fresh and minty! LOL
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
    November 2003
Posted by Mike F6F on Tuesday, January 23, 2007 7:39 PM
Like Ron I went from enamels to acrylics.
A question though? How well do they work together?
If I prime with an acrylic, so that I can paint white over a dark gray plastic, is there a problem spraying
white enamel from a spray can? I never could airbrush white enamel and I'm not ready to try white
acrylic.
Thoughts please?
Thanks,
"Grumman on a Navy Airplane is like Sterling on Silver."
Posted by waikong on Wednesday, January 24, 2007 8:30 AM
I've done the reverse many a times. I've primed with a enamel or Lacquer primer and than sparyed acrylic with an airbrush with no problems.
    June 2004
Posted by jsfman on Saturday, January 27, 2007 12:37 PM
Question
Can you do it the other way?  Spray down an acrylic and then spray a dullcote or glosscote over it?
More Thrusties!
