DesertRat wrote: |
But size is kinda an issue too. With an apartment, noise and bulk are my two biggest concerns. ... Can you recommend any brand names or manufactures? Thanks! |
Size? Well, the largest part is the tank, compressor itself is usually put on top of it, so, if you want compressor with a tank, you can't have it smaller than the tank itself :) With automatic "on/off" switch you don't need to have it nearby; you may put it somewhere under the table, just so you can get to pressure regulator from time to time; mind the lenght of hose and safety, though; don't put it near, say, an open bottle of easily flameable laquer or something. :)
As for brand names, nope; my own compressor I've made from a piece of an old iron pipe and old refrigerator's compressor; it's powerfull and nearly absolutely silent, just like a refrigerator:) , although bigger than small "garage compressors" I've seen aplenty in very broad range in just usual equipment shops (big ones, though. You know, shops where you buy household equipment, small electric saws and such). All compressors here are german-made; my father have 3 of them for different purposes in his summer house, they were cheap, work quietly and reliable, without smallest problem, for years and years.
