Actually, it does turn it into a single action (well sort of). It doesn't limit travel the way the Iwata handle does, because when you depress the trigger, a preset amount of paint is sprayed because the needle is pulled back a certain distance already. With a travel limiting system, no paint is sprayed at first, but the amount sprayed is limited by the amount of back travel allowed. HTH.
E
