"Soft" edges on color transition
    February 2007
Posted by Shogun on Friday, March 2, 2007 11:01 AM
I am planning a mult-color paint scheme where I would like to have soft edge transitins between colors.  I have a plan in mind but I wanted to share it with the forum and see if I am forgeting anything or if there are better ways of doing this.  I am new to this so I just want to be sure.....
My plan is to cut a mask out of regular old paper you would put in your printer. I was going to attach the paper mask with rubber cement in the middle of the mask so that the edges will be slightly raised off the surface of the model.  At this point I plan on using my airbrush to paint at a very slight angel to the edge of the mask, but not to much of an angel that it bleeds too far under the mask (I guess this is more art then science).  I am assuming I put the lightest color down first and then the darker color.
Anyone see anything I am missing, or should consider doing?  Any other techniques anyone has had success with?  Thanks.
Travis
Travis Parker On the Bench: - F4G/F Phantom II "Wild Weasel" (Testors) - Ducati Monster S4 motorcycle (Italeri)
Moderator
    April 2006
  • From: my keyboard dreaming of being at the workbench
Posted by Aaron Skinner on Friday, March 2, 2007 11:50 AM
Travis,
It depends on how soft you want the demarcation lines to be. Spraying straight down on the mask edge will give you less bleed. Spraying away from the edge will give an even harder line. I'd be careful about spraying toward the edge. The air flow may lift the mask, allowig more paint to bypass the mask.
Hope this helps.
Aaron Skinner
Editor
FineScale Modeler
    May 2003
Posted by klem on Friday, March 2, 2007 12:04 PM
This is what I've done in past; I've cut out the shape of the mask then I take small pieces of low tack masking tape, roll them over into little tube shapes then attached them to the underside of the mask. I put the rolled pieces of tape about 3/16" away from the edge of the mask. I also put many pieces along the edge of the mask about a 1/4" apart.When you tape the mask to the model after you press down it should stay up a little bit, maybe a 1/16" or so. I read this in one of my model books years ago and I've done this on many a model, even in 1/72 scale with great results. It is somewhat time consuming but it does work. I still do it this way due to fact that I still don't have a real airbrush.My 2 cents [2c]
"We the unwilling, led by the unknowing, are doing the impossible, for the ungrateful. We've been doing so much for so long with so little we are now capable of doing anything with nothing." Unknown
Posted by ajlafleche on Friday, March 2, 2007 2:11 PM
If you have even a modest airbrush, such as the Paasche H single action, you should be able to freehand your pattern. Just place the tip way close to the surface and spray carefully. It'll take a lot less time in the long run than cutting and taping masks and worrying about the paper lifting too much or the paint bleeding. Anglei into the color you're spraying and there's less chance of excess overspray.
Posted by ABARNE on Monday, March 5, 2007 9:37 PM
Shogun,
In years gone by when I had a Testor's A220 airbrush (not much more controllable than a rattle can), I had tried essentially the method you have described, and got inconsistent results, for exactly the reason that Aaron suggested, parts of the mask lifted more than others.
I got better results with Klem's method.  Because the edges are all fastened down, the softness of the edge transistion is pretty much dependant on how far off the surface the mask is.
On the other hand, after updgrading to a Paasche H, I easily I did a 1/35 tank camo freehand.  As Ajlafleche says, get the tip in close and carefully spray.
    February 2007
Posted by Shogun on Tuesday, March 6, 2007 12:28 PM
Hey Everyone,
Thanks for the information on this.  I have been real nervous about this leading up to a couple of projects I have on the bench (I am pretty new to the hobby)  I found a really low end partially completed model of a P-40 fighter at a garage sale this weekend.  I will use that as practice foder.
I have about a 15 year old Paasche type H airbrush that has hardly been used.  Is that the same Paasche H you are referencing?  If so what size tip are you using for this work?  Thanks again everyone.
Travis
Posted by ABARNE on Tuesday, March 6, 2007 2:16 PM
That would be the one, simple and reliable.  Paasche has been making the Model H for the better part of century.  They have no.1, no.3, and no.5 tips for narraw, medium, and wide coverage.  I usually use the no.1 tip.  With that tip, one can easily spray a line that is somewhere between an 1/16 and 1/8 of an inch wide.  I've never experimented with seeing how narrow one can get with the no.3 tip.
Just experiment with geting the proper paint consistency and air pressure and move the tip in close to the surface.  You'll be amazed at what you can do.
    February 2007
Posted by MrDrummy on Thursday, March 8, 2007 8:12 AM
Shogun,
I've not used a mask in ages.  I freehand all my camo patterns, like some of the other posters have said.  You have to be careful when you're getting close to the surface of the model that you're not spraying too hard.  If you've got a regulator on your air source, make sure to turn it down a bit.
I've also found if I'm not completely satisfied with how tight the pattern is, you can keep switching between the two colors and spraying the edges til the pattern tightens up.  It's always worked for me!
-Justin
On the Bench: 1:48 Dragon Dr. 1 1:48 Trumpeter MiG-15 Fagot B Photo Sharing and Video Hosting at Photobucket
    September 2006
Posted by shall on Wednesday, March 14, 2007 3:07 PM
I take a brown paper bag like you get at the grocery store and instead of cutting the mask, I tear the paper into the shapes I need.  This works well (for me) doing camo patterns on armor which are usually done in the field and can be pretty rough to start with; probably a little too rough for aircraft.
shall
