Tanky, ARRGGHH!! My sticky trigger problem returned after only one painting session. I'm contacting Adam again, and now I'm just pissed given how much time I've spent trying to solve this problem, and the fact that I'll probably have to send it back to him again. Hope you have better luck. Now I'm totally paranoid that my CM-C+ will develop the same problem. I still can't shake the feeling that the Lube had something to do with this mess, since I never had the problem with the HP-C+ until I used it, and I've never used it on the CM-C+. I know, it doesn't make sense, but my gut tells me there's some connection. This has stymied me on so many on-going projects since the HP-C+ is my "middle-ground" AB. I use a Paasche VL for large area work, and the CM-C+ for really fine stuff, but my HP-C+ was the one I used most. TomB |
