Vallejo pros-cons
    August 2006
Vallejo pros-cons
Posted by Gun Tech on Friday, March 16, 2007 7:58 AM
I would like to know what you guys think about Vallejo. I'm looking to buy new paint very soon.
I was using Tamiya, but think it s***s for handbrushing.
What are the pros-cons for Vallejo? What is the drying time when handbrushes?
Cheers!
Jean-Michel    "Arte et Marte"
    January 2007
Posted by IYAAYAS on Friday, March 16, 2007 8:51 AM
IMO
Advantages: Goes on very evenly, and very "brush friendly" with a lot of colors available
Disadvantages: When applied to resin, you MUST clean the piece very well, I've had some problems with the paint not adhereing.  Expensive and does not thin for airbrusing very well (I know there is a "series" for airbrushing)
Drying time depends on the enviroment, but it cures in about 24 hours.  By cures I mean it's completey dried!
Posted by ajlafleche on Friday, March 16, 2007 11:05 AM
The only real disadvantage is that it's hard to find. Only one dealer in Massachusetts carries the full line. He may be the only person in New England, for that matter.
It does take a bit of time to learn how to use it, but once you get used to it, you'll wonder why nayone would use any other acrylic paint. Remember to use well thinned coats to build up the color. You can apply additional coats minutes after the previous coat has been laid down with no lifting of the previous layers.
Posted by Anonymous on Friday, March 16, 2007 2:26 PM
i always thought it was great for airbrushing.  cut it 50/50 with plain tap water and blast away.  dries to the touch in a minute if you don't hose it on.
there's at least 2 dealers in new england:  shop here in CT has the whole line (both vanilla and airbrush varieties) in store constantly.
the pros is that they work great, are easy to mix, come in good variety of colors (which i never take advantage of anyway) and come in bottles with dropper tips so they're easy to handle.  the downside is that if you're going to use them for airbrushing you have to expect a clog every now and then since they're not "airbrush grade" (but this never makes me lose any sleep) and that they're a bit more expensive.
    August 2006
Posted by Gun Tech on Friday, March 16, 2007 3:01 PM
So Vallejo it will be.
I know a Hobby Shop online in Canada where I can order (that's where I buy most of my kits).  I don't really care about the price....  after all, after building and detailling a model for a few months, I want a good looking paint and finish to go on it.
Thanks a lot guys!   Cheers!
Posted by Anonymous on Friday, March 16, 2007 6:44 PM
I have both Model Color and Model Air Color.  I haven't had to much luck with fine lines with the Model Air Color, but it works great for general coverage.  The Model Color is great for hand brushing and you can airbrush it if you like by mixing it 50/50 with distilled water.  You can order it online at a few places.  Here are some links:
http://www.coloradominiatures.com/index.asp
http://store.valueweb.com/servlet/darksondesigns/StoreFront
http://store.usacomicbooks.com/
I have used Colorado Minatures and have been very happy with their service.  Take care.
Rob
    August 2006
Posted by Gun Tech on Friday, March 16, 2007 8:26 PM
Thanks Rob Smile [:)]
    October 2005
Posted by tabascojunkie on Saturday, March 17, 2007 1:26 AM
Thinning Vallejo Model Colors and most other water based acrylics with Windex works well. Use the original formula Windex and start at about 2 to 1 paint to thinner.
Bruce
Posted by Anonymous on Saturday, March 17, 2007 8:47 AM
do you end up with a slight blue-ish tint on all the paints?
don't forget you can get a box of acrylic retarder at michael's.  add a drop to the paint and get a smoother stronger finish.
    August 2006
Posted by Gun Tech on Saturday, March 17, 2007 8:58 AM
That makes me think of another question.....     Can you get Vallejo off easily if you make mistakes?
Posted by Anonymous on Saturday, March 17, 2007 9:09 AM
sure, it's still acylic.
    October 2005
Posted by tabascojunkie on Saturday, March 17, 2007 9:14 AM
No, the blue fades away after you mix it in the cup. I use the Vallejo Game Color white primer on my miniatures and the blue isn't even noticeable in the white.
Bruce
    October 2005
Posted by tabascojunkie on Saturday, March 17, 2007 9:20 AM
My only experience with removing Vallejos is on pewter miniatures, and Winsor & Newton brush cleaner does a quick job of that. But I understand it'll also quickly destroy plastic, so I wouldn't try it on a model kit.
Maybe a soak in Windex with a scrap part would find out if it'll work for it after it's dried.
Bruce
    June 2006
Posted by MaxPower on Saturday, March 17, 2007 12:02 PM
Have you tried Pollyscale?
    August 2006
Posted by Gun Tech on Saturday, March 17, 2007 12:11 PM
No I haven't. I was using Testor Enamel a few years ago. Switched to Tamiya a couple years ago without doing any kind of detailled painted until recently. I just read a lot of good things about Vallejo, and I know that their color selection is quite diversified.
You prefer Pollyscale over Vallejo? I'll be really interrested to know why as I haven't bought anything yet Wink [;)]
Cheers Max!
Posted by Anonymous on Saturday, March 17, 2007 12:59 PM
Cheers Max!
 polyscale makes my favorite clear coats:  they're sprayable directly from the bottle and hard to over-do.  the only problem with polyscale is that the paint tends to lump up into a rubbery stringy mess in my experience.
i switched to gunze sungyo after polyscale (except for the clears) and used those until i discovered valeijo.  they have a great selection of colors which is actually referred to in painting instructions on kit and are very easy to spray, plus they're a bit cheaper than valeijo but that advantage of the dispenser bottle just outweighs the price for me which is why i use valeijo.
    August 2006
Posted by Gun Tech on Saturday, March 17, 2007 1:56 PM
Well, you got me convinced Goat Monkey Big Smile [:D]   Vallejo is my choice. Gotta wait in April before having the money to order though.......  but I'm sure it will be worth it Smile [:)]
Posted by Anonymous on Saturday, March 17, 2007 4:36 PM
actually if you have a place around that sells the gunze paints and don't mind messing with droppers to dose out paint, i'd go with those.  a good part of why i use the valejo's is that i almost always end up mixing up colors instead of just using what's in the can so the dropper tip is a BIG plus for me but i don't know if you have that particular kind of insanity Smile [:)]
sorry to sound like i'm flip-flopping, i just don't want you to end up with a whole bunch of the mor expensive paint all at once and be unhappy with it.  definitely give them a try though.
    November 2014
Posted by vtrockin on Wednesday, March 21, 2007 12:06 PM
i've also ordered Vallejo from http://warweb.com
They have model air & model colors stocked.
    February 2007
Posted by roosterpelo on Friday, March 23, 2007 2:22 AM
i also have been a tamiya junkie for quite awhile. but everytime i try to handbrush it, i get nasty streaks, and i always read about how great vallejos are. i bought mine from www.ausfwerks.com and their prices are really great. i haven't tried them yet, but they look really nice. i also use pollyscale because i find that they have some colors that tamiya dosen't, like dust. also like someone already said, their airbrushable right out of the bottle. so from my limited experience, tamiya are great for base coats, and simple applications, when you want to get better tones and variations, switch over to pollyscale. then with the handpaintind parts, try the vallejo.
chris d.
    January 2006
Posted by PatlaborUnit1 on Saturday, March 24, 2007 11:53 AM
Tamiya is not really made for handbrushing unless you use a product like Liquitex SloDri to extend thedrying time, otherwise it just dries quicly on the brush as the alcohol based sovent dries.
I use a lot of Reaper paints which are very similar to Vallejo. I thin with a few drops of tap water (actually from my filtered water tap) and add a drop or two of the Slo Dri. It stays in the paint well ( i use those cheap white plastic paint tray things from Walmart)  for quite awhile even under hot lights.  I apply the paint with a brush that has been dipped, and then wiped dry. You will still have residual paint that will apply when you lay on the brush. Try it! it works great, you have control over your layers and you will get more subtle gradiations.
You can thin Vallejo for airbrushing with thier glaze medium, which thins the paint for airbrushing without actually degrading the opacity of the paint.
HTH
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
