zlee11 wrote: |
I will drop the pressure to 15 and see how it goes. |
15 PSI should be fine. I have a Paasche H, and that is what I spray at.
zlee11 wrote: |
I do not like to thin paint because you can not put the unused paint back in the bottle. |
In my experience, that admonishment really applies only to enamels. Once enamels have been thinned for airbrushing, they cannot be stored for long periods because the thinner will separate and the pigments and binders will clump up in the bottom of the jar and be utterly unusable. No amount of mixing will help.
With acrylics, and I've observed this with both Tamiya and ModelMaster Acryl, the paint will separate just as with enamels, however unlike enamels, you can simply stir up the paint and it will paint as perfectly as the day it was thinned. I have kept some highly thinned acyrlic mixtures for more than a year with no troubles. The paint does separate, but before use, I stir it up and I'm good to go.
Recently I opened a bottle of MM Acryl flat black only to discover that most of the thinner or carrier had evaporated with paint being a clumped up gooey, almost rubbery mass in the bottom of the jar. (I suppose I must not have properly tightened the lid when I had previously used the paint.) Had that been an enamel flat black, I would have thrown the paint away. Never having tried to revive an acrylic that far gone before, I put in some Tamiya Acrylic thinner and stirred. Amazingly, the paint dissolved back into the the thinner and is as usable now as when I bought it.
zlee11 wrote: |
Tamiya is pretty thin. I will thin if I have to. |
Always look at each paint bottle individually. Although Tamiya acrylics seem to be more consistent that Model Master enamels, I still see a noticable bottle to bottle variation on how thin of thick the paint is.
