Airbrush Painting Camo
    February 2007
Posted by aj2wins on Saturday, March 17, 2007 4:49 PM
Iam still working on my F-4 paint job.
Still not satisfied with the first paint job.
In the process of taking the paint off and starting again.
Trying to free hand the paint job with a spraybrush,
is a little more diffucult than I thought. My question is,
is there a way to paint the different colors of the f-4
by taping or using another method without having the demarcation lines
from the tape.Iam using enamel paint.
Posted by ABARNE on Thursday, March 22, 2007 2:58 PM
It depends on how soft and edge you want.  You can use lengths of rolled up tape just inside your mask edges to lift the edge of the mask a bit.  With som experimation on air-pressure and distance form painted surface, you might be able to get the right effect.  I have used that method prior to having a controllable airbrush, and it worked somewhat.  The effect wasn't so much that of a soft transition as that of simply taking a bit of the starkness from it.
What kind of airbrush do you have?  Even a very simple single action like a Paasche H can easily do fine enough lines to allow you to do free-hand camo, but like everything with airbrushing, it is a matter of practice and experimentation.
