Can't open airbrush thinner!!
    May 2006
Posted by aagranata on Monday, March 26, 2007 3:49 PM
Okay...I feel really dumb.  I've got three bottles of Testors airbrush thinner and I can't open a single one of them.  I press and turn until I'm blue in the face, but no luck.  Why does this always happen and how can I fix it?????
One good hour working on a model erases 8 bad hours at work!!
    February 2006
Posted by Wulf on Monday, March 26, 2007 5:59 PM
Try pliers to get 'em open. Works for me.....
    August 2005
Posted by EdGrune on Monday, March 26, 2007 6:54 PM
What I think may have happened is that you sealed the can on a warm day and once the can got cold the vapor condensed and you pulled a vacuum on the can.   The vacuum is causing the lid to seal really tight.   Put the can in a warm water bath for a few minutes then try it again.  Else use the pliers recommended above.
    June 2005
Posted by MontanaCowboy on Monday, March 26, 2007 8:10 PM
Take the plastic part of with some pliers and force, then you won't have to worry about it again.
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly." No wait, that's not it.
