- Member since
November 2003
Ultrasonic Cleaner questions
Posted by bobbaily
on Wednesday, March 28, 2007 2:08 PM
Greetings all. I just purchased an ultrasonic cleaner to clean my airbrush. (I told my wife that it would be ideal for cleaning her jewerly ). Based on previous posts, I recall that some of the regulars here have used an ultrasonic cleaner, so I have a couple of questions-(btw, I'm using acrylic only)-do you use water (distilled) or Windex (or other solution)? Do you disassemble the A/B or clean it intact? How long should it stay in the cleaner? I'm also assuming that if I use a solution other than water that I should spray some distilled H2O thru it, followed by some Regdab. Thanks in advance.
