airbrush problems
    September 2006
airbrush problems
Posted by david on Friday, March 30, 2007 7:56 AM
the air flow on my airbrush is fine but when I let the paint through it seems to be half blocked ive cleaned it well  and I just can't get it
it goes sssssssssssssshhhhhhhhhhhhhhhhhhed .......................sssssssssssssssssshhhhhhhhhhhhhhhh...............
sssssssssssssshhhhhhhhhhhhhhhhhhhhhhed............................ssssssssssssssssssshhhhhhhhhhhhhhhhh...............
and so on
DAVID
    January 2007
Posted by Gigatron on Friday, March 30, 2007 9:08 AM
Could be the paint isn't properly thinned or the PSI is too low.
Also make sure that the AB needle isn't bent or warped.  It won't affect the air flow, but it'll really mess with your paint.
What make/model airbrush is it?  It may be a known problem with your particular AB.
-Fred
    September 2006
Posted by david on Friday, March 30, 2007 9:46 AM
I don't have the exact details here but it's a pasche double action
I'll try the other things as well
DAVID
    January 2007
Posted by IYAAYAS on Friday, March 30, 2007 9:55 AM
did you check to make sure all your seals are there?  Sounds (as you typed it) like you might have a missing/broken/bad seal.
