Raising air pressure allows you to get better aspiration and atomization of thicker paint.
To get better flow, both through the brush and on the surface (leveling) thin the paint more. If for some reason you don't want to thin it (or you didn't get it thin enough) move in closer and drop the pressure slightly.
Paints that are intended for brushing with bristles are much too thick to airbrush—and most paints are manufactured to those viscosities because proper dispersal of the pigment requires them. Paint viscosity is adjusted after it has met color requirements.
As a general rule of paint-stained thumb, paint with "normal" viscosity has to be reduced 30 to 50 percent for aerosol application, whether from a spray can or an air brush.
