jean wrote: |
Whenever I apply Tamiyas Flat Clear paint over my existing paint job a white residue is left. Does anyone know why this is happening. |
This question seems to pop up once a month. Tamiya's Flat Clear (X-21 Flat Base) is not a clear coat in and of itself. It is an acrylic paint additive that is used to flatten a gloss or semi-gloss paint or clear coat.
To use it for a flat clear, mix it with Future floor finish at a ratio of four parts Future to one part Flat Base. I think that ratio gives a nice, flat finish. For an even flatter coat, you can go down to three parts Future to one part Flat Base, but at those concentrations, you have to be very careful to not spray too heavily or you'll get the frosted effect. Alternativelty, if you want more of a satin to semi-gloss decress the amount of Tamiya Flat Base.
You can also use it with paint, and when used with paint, I don't think the mixing ratios are as critical as they are with clear. I have a bottle of ModelMaster Acryl Rust that has a good rust color but is just a bit too satin for a convincing rust, so I mix it with Tamiya Flat Base and it comes out excellent.
