Adriaran wrote: |
I'm currently using oil or enamel based paints for my models. They're kind of expensive, and it doesn't come with much paint. |
Quite. Don't figure out the cost per gallon—you might give up modeling…
Adriaran wrote: |
I've noticed quite a few of the guys here on the forum say they use acrylic paints. Acrylic meaning the kind of paints you can get in the tall, 2 oz. containers for a buck at your local craft store? |
NNNOOOOoooooo! Not the same at all, although some have posted that certain brands seem to work. Paints formulated for plastic models are rather specialized—they're intended to bond to plastic, for one thing, and pigments are probably considerably more finely ground. Those are the things you would notice first.
Adriaran wrote: |
Do these paints act differently in an airbrush? |
Yep.
The only real answer is to become a paint miser: never thin (reduce) more than you need for a given task (a matter of experience—you can always stop and thin more). Never thin a whole bottle. Never return reduced paint to the original bottle. Learn how to keep paints in good condition for years. (FSM has apparently bought my article on the subject, so hopefully that will appear in the near future in some form or another.)
I find modeling acrylics much easier to use. The primary difference is that with acrylics, application to a CLEAN substrate is absolutely necessary. By clean, I mean nearly surgically clean—not sterile, but no contaminants on the surface at all.
