Madroc wrote: |
1. I can't get the last of the paint residue out of the color cup, at the bottom where it goes from a smooth to a rough surface. How big a problem is that? Should I just soak it in solvent overnight? 2. What kind of care is normal? Do you need to strip it down and soak the parts in solvent every time, or just shoot some solvent through it and wipe off anything on the outside? Do you only need to shoot solvent when you're just changing colors?
I've been using a Paashe H for a few years, and I haven't found it necessary to fully break it down after every use. My normal cleaning regimen is to spray solevent through it, wipe it down, and call it good. Every now and again, I do perform a full breakdown, just to say I did more than due to any real necessity. When I do fully break it down, I don't see much if any in the way of left over paint residue. Any that is present has never affected my painting, either in terms of spray pattern or in dissolving into the the current paint color.
About your color cup, I've never had that problem. The cleaning regimen I use for the color cup is to first dump the excess paint. I then fill the cup about half way with cleaner, and brush the inside with a cheap paint brush that I keep for cleaning. I dump out the thinner and fill it again halfway with thinner, again brushing the the inside. To clean the tube, I put the tip of a plastic pipette into the end of the siphon tube and gently squeeze and release the bulb which pumps the thinner back and forth through the tube.
With the color cup cleaned, I dump out the cleaner and again re-fill it about half way with cleaner, and put back on the airbrush. I then spray cleaner through the airbrush to clean the tip. Two or three times while emptying the color cup, I will backflush be placing my finger over the nozzle which forces air back through the tip and into the color cup. When you do it right, you'll see bubbles in the color cup. This backflushing helps stir things up inside the tip to help get out all the paint residue. I'll also use my cleaning paint brush to clean the tip and nozzle. After the color cup is drained of cleaner, I'll usually repeat the process and spray out another half color cup worth of cleaner.
Madroc wrote: |
3. What are the advantages/disadvantages of using the cup vs. the jar? |
Depends how much paint you are spraying. Most often, I don't need to paint much so the color cup is ideal. It's surprising how much even ten or twelve drops of paint will cover, and you can use that sort of a paint quantity in the color cup whereas with a siphon bottle you need to have a much larger minimum paint quantity.
I'm the opposite of Air Master in terms of cleaning preference and find the color cup faster to clean and using less solvent to do so. Another consideration is the color cup is a smaller and more out of the way, so it is easier to maneuver the air brush close to your work. It, of course, has the disadvantage of an open top with the risk of paint spillage.
Madroc wrote: |
4. Does lower paint flow= thinner lines? |
Basically right, although the painting distance is of course a factor. tighten down the tip and and move close to the surface, and you can get some very fine lines with the No.1 tip. Freehand camo in 1/72 scale is quite feasible.
Madroc wrote: |
I like the results so far but I haven't tried anything serious yet. |
The Paasche H is an old design (original patent 1908), but gets the job done with a minimum of fuss and is as rugged as anvil. The more you use it and the mosre experenced you get, the more you'll like it.
