Help me decide between these two Iwatas.
    June 2006
Posted by MaxPower on Thursday, April 26, 2007 5:57 PM
I am going to treat myself to an Iwata gravity feed and have narrowed it down to these two options.
1) HP-C plus
2) Eclipse HP-CS
The HP-C plus is about $40 more. Does it have any real advantage? Is it money well spent? Pros and Cons of these or personal opinions welcome.
This will be used as my fine detail/general painting brush and my Badger 155 Anthem will be my large coverage and Future brush. I will spray mostly acrylics but at times enamels and occasionally lacquer so the odd solvent will go through.
Thanks guys!
    June 2006
Posted by MaxPower on Friday, April 27, 2007 2:40 AM
Uh-oh. My wife thinks if I get a new airbrush she should get a new faucet for the kitchen. But we rent, that would be a waste of money. She thinks having two airbrushes is a waste of money. So then I pointed out how much her smoking costs per month. Wrong answer. Oye.
I don't drink or smoke, all I have is good food and modeling. lol.
Posted by Anonymous on Friday, April 27, 2007 6:39 AM
I myself am still a novice but have read a ton of older threads which have been very helpful on this very issue. I just ordered an HP-CS from Coast Airbrush (very nice and helpful people, BTW). As I understand it, the HP-CS is real good for the heavier pigments we use with modeling paints. You can also pick up a 0.5 mm n/n combo to spray even heavier paints if one chooses. The reliability of the Iwatas seems to be outstanding, as well. I'm waiting patiently for mine to arrive!
Posted by Anonymous on Friday, April 27, 2007 9:27 AM
HP-CS!  Great performance ( hairline if practiced ), parts are cheaper, and as stated, can handle heavier pigments if needed.
E
    June 2006
Posted by MaxPower on Friday, April 27, 2007 9:52 AM
Yes I got it in gear and searched out some old threads.
Looks like it's an HP-CS.
    June 2006
Posted by MaxPower on Saturday, April 28, 2007 10:23 AM
It's done. One HP-CS on the way. Ordered from an online store in Ontario for 103.99 USD. A good price.
    July 2004
Posted by mucker on Wednesday, May 9, 2007 8:32 AM
My 2 cents:
I use the Iwata Eclipse for just about all General Purpose work (all acrylics). The airbrush it self is top notch: great quality, easy dissasembly for maintenance and easy to use. The only downfall is it doesn't spray hairline patterns, at least with the factory set-up (or maybe it's me who is the problem!).
I have to switch to a second AB for fine detail, but if I could have only one, the general purpose Eclipse is a real workhorse. The HP is a step above the Eclipse, but as you said, more expensive. I'd make your choice based on what your airbrushing needs/preferences are.
    June 2006
Posted by MaxPower on Friday, May 11, 2007 3:10 AM
I got the Eclipse and I love it. I swear it has magical properties! Laugh [(-D]
Posted by jhande on Sunday, May 13, 2007 8:34 AM
Hey Niall,
I think you will enjoy and have fun with your new HP-CS.
I've been playing around with mine for awhile now and can achieve pencil line to 2 inch patterns rather easily. My friend at his bodyshop has no problem with the hairlines... lot's more experience LOL. He guided me towards the CS rather than the C+. He proved to me I wouldn't need the 0.2-mm nozzle, that the 0.35-mm will suffice. Iwata's folks told me for spraying our heavier paints (not ink or dyes) that I wouldn't notice much difference between the 0.2-mm and the 0.5-mm nozzles.
I started with the BCS as I spray mostly car models one color (also the wife wanted to do T-shirts and I'm spraying 1:1 car graphics). But the cup on the CS holds enough paint that I am using the CS now for my models. I do use a Vega 600 though for primer or clear top-coat finishes.
Don't forget - play with the paint consistency, air pressure and distance from the object besides the trigger. Smile,Wink, & Grin [swg]
-- Jim --
"Put the pedal down & shake the ground!"
