what I do is start with an empty 1/2 ounce jar (ex-Pollyscale/Warbird/Testors Acryl) and add two pipettes worth of Tamiya thinner (you need the retarding agent in it) and add almost the whole bottle (the mini bottle that is) of paint leaving just a little room in the top for the the paint strainer/filter.
(I use an in-line paint filter on my Badger 350F, it prevents clumps of paint from blocking the tip)
the retarding agent in Tamiya thinner helps keep the tip from clogging and helps keeps the paint flowing so I get more painting done and less time cleaning the tip.
as for brushing by hand with a paint brush...I've only done that once (and one with Gunze) and it was a disaster that I will not repeat.
in short use Tamiya and Gunze ONLY in your airbrush !
EDIT : I mixed some gloss white (X-2) with some X-5 Green and used it to paint-by-hand with a brush and found it to be quite excellent.
I'm beginning to think that there is something in the flat paints that isn't in the gloss paints and that is our culprit
