I suggest you go to Testors' website at http://www.testors.com/ and look at their selection by clicking on "Aztek".
Read the descriptions and pick the one that suits you the most.
As you might notice the largest and most expensive one (the $400 model)has a receiver tank, and it is being sold as the "perfect compressor for the person who uses their airbrush all day long" as the tank keeps you air at a constant volume so you don't find yourself "fizzeling out" when doing a large job. Essentially this one is the $350 model with a tank added, and for only $50 more, I can hardly believe that they would sell more of the models without the tank.
The moisture trap, which is on both of the higher-priced two models, is essential especially if you are in a humid or wet area where the air you are using would contain enough moisture to cause your paint to splatter while spraying. The compression of the air condenses any moisture (humidity) in the air, resulting in actual water droplets which can come out of the spray gun.
As it turns out, if the $349 model would suit you, you can get the same basic unit at Harbor Freight for under $100.
OK?
Tom
Tom T
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
