Badger Crescendo 175 - Need help :(
Posted by Anonymous on Sunday, May 6, 2007 2:19 PM
Hi, I just started airbrushing I went out and bought A Badger Crescendo Model 175.
I was using an acrylic paint, on it it says you can thin it with water I'm assuming I don't need to do anything with it if it's thin enough. At first it works fine after 20 minutes.. didn't really paint much, just first base coat (learning true fire) and it just stops sucking paint out of the bottle. No paint at all wants to go through or into the brush, it just wants to waste A lot of air. Wasted a few 14oz propel bottles trying to spray paint. I tried every tip/needle/cap combination that came with the brush, they all do weird things and it's hard to find right setups. But anyway no matter what, no paint goes from the bottle to the gun. But I can mix the paint in the bottle by covering the tip so apparently nothing is blocked?
I don't think it needs to be cleaned, and if it does then I'd hate to clean it after every few sprays...
Any ideas?
    August 2005
Posted by eizzle on Sunday, May 6, 2007 5:13 PM
Well, the first thing I would do is see if your acrylic paint isnt getting a film on it causeing a clog when it sucks the paint into the brush. Acrylics skim over very quickly. If it is, go to an art supply store and get a bottle or acrylic retardner. It will slow the drying time down. If that doesnt work, try using a different color cup if you have one, you might have a slight crack or something in the current one?
Colin
 Homer Simpson for president!!!
    August 2005
Posted by Phil_H on Sunday, May 6, 2007 6:47 PM
The absolute worst thing about using propel cans is the pressure drop.
It's basic physics. The conversion of the liquid contents of the can to a gas when the valve is opened provides "air" for your airbrush. At the same time, the temperature of the liquid propellant drops. As the temperature drops, so does the pressure of the gas being released. Incidentally, your refrigerator works on the same principle.
If you airbrush for long enough, on humid days you may find ice forming on the outside of the can. Typically, with a propel can, you'd have about 10-15 minutes continuous use before the pressure drop sets in. Eventually it will drop far enough that it will refuse to pick up paint (particularly with siphon-feed models), even though there is still air flowing through the system.
Apart from switching to an alternative air source, There are only limited ways in which you can overcome this problem.
  • Only use the airbrush for a few minutes at a time and allow the can to return to room temp.
  • Stand the can in a container of warm (NOT hot) water until it reaches room temperature.
Posted by Anonymous on Sunday, May 6, 2007 8:04 PM
Oh that's nice info. yeah my cans are turning into ice and it's not that humid out yet. Never thought that would cause not picking up the paint. I guess I'm going to buy a compressor I was hopeing I didnt have to until I got better at airbrushing, oh well.
Thanks for the explanation!
    June 2006
Posted by MaxPower on Sunday, May 6, 2007 8:48 PM
You'll want to get a compressor sooner or later... may as well be sooner! Smile [:)]
