Cleaning Help
    March 2007
Cleaning Help
Posted by Medic18 on Thursday, May 10, 2007 9:46 PM
Guys, I just bought a Paasche VL.  I never used a air brush before but I want to kick things up about 5 notches.  I normally use Testors Model Masters Enamels when I paint.  What kind of cleaner should I use for the brush. (e.g.  Any specific brand)  What are your prefrences.  I want to start practiceing with it, but I want to make sure I take care of it when I use it.  THANKS!
        Chris
"Failure isn't failure,if a lesson from it's learned."
Posted by Anonymous on Friday, May 11, 2007 3:25 AM
Enamel thinner. Big Smile [:D]
Just go to your hardware or auto supply store and get a gallon can of it, ensure that it is an enamel thinner.  There is no need to get a specific brand name just for cleanup.  Some guys swear by having a 'general' thinner for every day cleanup, and then a heavier Lacquer thinner for the thorough cleaning jobs once a week/day/month/whatever.  Experiment a bit and see what works best for you.
I also recommend scouting out a small rubbermaid container that is sturdy and large enough to fit your brush in when broken down.  This allows you to soak the brush in a sealed container (less fumes).
As always, plenty of ventilation when working with this stuff (respirator if you have it), but that should be as elementary to model working as "don't cut towards your hand with that razor knife".
Lastly... and this is an enforcement of what was stated in all threads about this stuff:  Consider your health.  Look into getting a paint-grade respirator.  You can get them at any good hardware store or places that carry this sort of chemical.  Do a search here in the forums, I've posted everything on mine that I bought a while back.
    March 2007
Posted by Medic18 on Friday, May 11, 2007 5:19 PM
Chimera, Thanks for the reply.  I just wasn't sure if there was any specific cleaner for a air brush.  I spent some decent clank on it and didn't want to ruin it by using something too strong and volitile.  I do have a Scott pack at my disposal but I think that's a little over board.  Actually I already have a few NIOSH respirators and I will be working in a well ventilated area.  The spray booth thing is being worked on and I just wasn't sure if they were any more helpfull with the painting process itself or if it was more of a safety and health thing.
    February 2006
Posted by Wulf on Friday, May 11, 2007 6:57 PM
I use lacquer thinner for cleaning. I spray some thru during and after a session. Works well and keeps the inside clean.
Andy
