- Member since
January 2003
- From: Peoples Socialist Democratic Republic of Illinois
Posted by Triarius
on Monday, May 14, 2007 9:58 AM
I don't know if oven cleaner will work for this, but if you have an acrylic under the Alclad, it should, provided it can get to the acrylic through the Alclad. If you try it and it doesn't work, try light sanding of the Alclad surface and then repeat the oven cleaner. Make sure you rinse the model thoroughly before sanding!
Ross Martinek
A little strangeness, now and then, is a good thing…
