- Member since
June 2005
Two ways, straw or nail. Method one, shake it up well, super glue a plastic straw (chopped about three inches long) to the nozzle so it is sealed. Get a collection cup where you want to store the paint. Now, Cover the top of your container's opening with tape so it is sealed, then cut an X in the middle with your exacto blade. Fit the straw inside, and spray away. When it stops, take it out, shake it some more, and spray again. Take the tape off the jar and PLACE the lid on it. DO NOT tighten the cap, the gas in the paint has to escape. Wait an hour then tighten the cap. Two, get a nail and hammer. Shake the paint, tip it upside down, and spray, it should spray color for two seconds or so, then it will just spray air. Let it run out of air. Shake it again, and spray it upside down again. Then when you're sure the air is gone, shake it up and spray it upside down again. After three or four times of this, set the can upside down with the cap on. (do this part outside and with some older painting clothes on) Ram a nail through the bottom, more air will release, then take out the nail. Unload the paint through the hole into your container. That's pretty much it!
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly."
No wait, that's not it.
