Fingerprints on, not in, basecoat
    January 2007
Posted by EnamouredwithArmour on Sunday, May 20, 2007 9:30 PM
 Hi,
 My learning curve for getting back into modelling has been fairly shallow so far but I did a stupid thing. I managed to get prints from the oils in my fingers onto the Tamiya acrylic base coat of an armour project. The underlying paint is fine, I just need some ideas to clean the oily prints off before moving on to clearcoat and weathering.
Dave
    January 2003
Posted by Triarius on Monday, May 21, 2007 9:52 AM
Once the Tamiya is fully cured (that means I'd wait at least four days, in this situation) you can wash the oil off with dish detergent and water. I know this works with Dawn and Ajax dish deteregents. The procedure is as follows:
  1. Make a small amount of soapy (detergenty?Confused [%-)]) solution, about 1 to 2 cups of water, and just enough detergent to make a little suds when stirred or shaken.
  2. Put on latex or nitrile gloves or finger cots. This is to prevent more fingerprints.
  3. Rinse the affected areas with this solution, wait a moment, then rinse with distilled or deionized water. Do not rub! Do not allow solution to sit on model surface. Then pat the model dry with a clean, lint free cloth or paper towel.
  4. Repeat step 3 if you still see fingerprints.
  5. If you have soft water, you can also use either Woolite or Dr. Bronner's soaps. In the case of Dr. Bronner's, "DILUTE! DILUTE! OKAY!" That is, use about two drops per cup of water. It doesn't take much.
  6. Allow the model to dry for at least 24 hours before overpainting.
