- Member since
June 2005
I would mask, personally. Paint the light color first. While this is drying, find a design which matches the one you want (or make one) and print it out. Place wax paper over the design and secure both of these to a mat or flat area with pins. Cover it with a light colored, flexible tape like Tamiya Masking tape, and use a curved blade to trace the outline. Pull away the inside, and cut a rectangle around the cut, use this to mask the plane, and paint the inside color.
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly."
No wait, that's not it.
