New to Acrylics. Need advice.
    June 2007
Posted by JohnMcD348 on Tuesday, June 19, 2007 10:53 PM
OK, I'm ready to build and paint my first models in about 25 years.  I bought alot of the Tamiya Acrylics to use on the models.  The only paints I have ever used back in the day was the old Testor Enamels.  What do I need to know to use these effectively?  Is there a "How To" or Primer on using these types of paints anywhere?  Speaking of primer, should or do I need to prime the model first?  THey are standard plastic models.  A Tamyia Spitfire Mk.I 1/48 and Revell Spit Mk.II 1/48.  LAter I'll move up to my 1/72 B-36 that's been sitting in the corner for the past 7 years.
I bought the cheap Testor/Aztec Wal-Mart airbrush set to start out with, prior to that I had the old pressure can stuff(25 years ago), and alot of brushes for painting.  I've read alot of posts reguarding thinning the paint using Alcohol and/or water for the airbrush, that doesn't sound too hard, just a little practice to figure out what works.  What else do I need to know?
Thanks
JTMcD. We sleep peaceful in our beds because Rough Men stand ready in the night to visit violence upon those who would do us harm.......G. Orwell
    August 2005
Posted by Phil_H on Wednesday, June 20, 2007 1:23 AM
Hi there,
Ross (Triarius) pretty much has Tamiya acrylics covered in the following recent threads:
Tamiya Acrylics vs. MM Acrylics ???
Tinning Tamiya acrylics! (Should be "Thinning", but the title was taken directly from the thread "as is" Big Smile [:D])
There are many other threads regarding the use of Tamiya acrylics.
One thing which is very important to note: If you have picked up a bottle of Tamiya "Flat Base" (X-21), be aware that this is not a flat coat. It's not actually paint - rather, it's a flattening agent which is intended to be added to a gloss colour to make it "flat". Many people make the mistake of thinking it's a flat coat and simply thin it and spray. This usually results in a model covered in sticky translucent white goo. It can be mixed with Tamiya Clear Gloss (X-20) (or Future) at approximately 4 parts gloss to 1 part flat base to make a clear flat cloat.
    October 2004
Posted by ikar01 on Thursday, June 21, 2007 10:47 PM
That can also be mixed into their regular paints too.  Can't it?.
Posted by Anonymous on Friday, June 29, 2007 3:23 AM
 Phil_H wrote:
Hi there,
Ooops my 'H' key somtimes doesn't work all that well.
 Not wanting to change the subject but what is the basic rule of thumb.
Arcylics is ok over enamels
But enamels is not ok over arcylics....
or have I got that around the wrong way?
Posted by ajlafleche on Friday, June 29, 2007 7:18 AM
Completely irrelavent if you're using an airbrush. I seal my figures painted in acrylics with a heavy coat of Testor's Dullcote laquer with no problem and this is a lot "hotter" than enamels.
You can brush paint as well as long as you've allowed the first coat to dry thouroughly.
A couple words on Tamiya. They are almost impossible to brush paint without arcane and alchemic mixes of just the right amount of their thinner or acrylic retarder and /or water or alcohol. Their colors are also not matched to any color standards as are model master.
    August 2005
Posted by Phil_H on Friday, June 29, 2007 7:59 AM
Even with an airbrush, if overpainting one type with another, always allow enough time for the first coat to fully cure before overpainting.
