How easily does lacquer thinner eat at plastic?
    December 2005
  • From: Ich wohne gleich um die Ecke von der Schule!(Ohio)
Posted by Doom Grr on Wednesday, June 20, 2007 5:59 PM
Specifically an airbrush head. I know you can run it through the airbrush and have absolutely no problems but if you were to maybe soak it in lacquer thinner, how careful must you be? I know a story of one of my friends keeping lacquer thinner in a plastic bottle. Ate through and got all over his table.
Nuts!
    January 2003
Posted by Triarius on Wednesday, June 20, 2007 6:42 PM
That depends entirely on what plastic it is. Most air-brush parts that are plastic are one of the essentially inert plastics (like Delrin™) and impervious to the solvents commonly found in lacquer thinners. It also depends to a lesser extent on the solvent blend in the lacquer thinner. Some are more aggressive than others.
The term "plastic" covers a host of synthetics that numbers in the thousands, and keeps growing.
