Future and Acrylics questions?
Posted by stevedb227 on Monday, July 9, 2007 6:17 PM
Greetings!
While not new to the hobby I have not sprayed with acrylics AND never used Future prior to decal application.
My questions are as follows:
When spraying future is is thinned and if so, with what?
Will future yellow over time?  If so would there be a substitute?
What should be the correct mix ratio when thinning acrylics (model master in this case) for spraying?
I look forward to hearing your opinions.
Thanks
Steve
When you are up to your neck in alligators it is difficult to remember the original objective was to drain the swamp!
    May 2005
Posted by Bgrigg on Monday, July 9, 2007 6:49 PM
Swanny's article is the definitive source of your answers:
http://www.swannysmodels.com/TheCompleteFuture.html
So long folks!
