Removing enamels
    July 2007
Removing enamels
Posted by GMFreak on Wednesday, July 18, 2007 12:55 PM
Hello... ahem... may I ask discreetly how to remove enamel paints from a model, if it is possible, or how best to avoid losing panel detail (or put it back in) after yet another coat?
    May 2005
Posted by Bgrigg on Wednesday, July 18, 2007 2:06 PM
Easy Off oven cleaner, or brake fluid will remove the paint without harming the plastic.
So long folks!
    July 2007
Posted by GMFreak on Wednesday, July 18, 2007 2:42 PM
Would any brake fluid work? Is it mineral or silicone based that I need? Alternatively, anyone know where to get 'easy off oven cleaner' in the UK?
    October 2005
Posted by usmc1371 on Thursday, July 19, 2007 7:13 AM
I've never had success with removing paint.  Either I can't get the paint out the corners or I damage the model.  An alternative is to prime the model with a good primer and then repaint it.  Just lightly sand as much as the model as you can, wash the model real good to remove dust, then prime.
Posted by MikeV on Sunday, July 22, 2007 6:49 PM
This may help. http://www.bonediggers.com/1-3/strip/strip.html
