rough paint
    September 2006
rough paint
Posted by Scottie on Thursday, July 19, 2007 1:57 PM
Sometimes when I use my airbrush the result is a rough finish on my model.  I have noticed this mostly when with black paint.  Using Tamiya acrylics.  Anyone have an idea what might be causing this?  I'm not sure how much air temperature and humidity might play into this or is just my technique.  I try not to paint when the humidity is above 50%.  Sometimes you can brush or rub off the roughness, if that makes sense.  I guess I could be using to much air when I paint.  The compressor is set to around 50 PSI and I have set the brush to have very little paint coming out.  Any ideas or thoughts would be appreciated.  Thanks.
    May 2005
Posted by Bgrigg on Thursday, July 19, 2007 3:30 PM
The paint is drying before it hits the styrene. 50PSI is WAY too much pressure for airbrushing. If you are using a gravity feed AB drop the pressure to 12-15, and if siphon feed try 15 to 25. Note that those are ranges only. Internal mix brushes usually need less air, while external mix ones require a higher pressure.
So less air, and get up closer to the plastic. No more than 6" away. I typically spray around 2" to 4" away and never more than 15PSI using my Badger 150 siphon feed. When I use my Badger 100LG I can be as close as 1/2" and as low as 8PSI.
Another thing to take into consideration is your thinning agent. Tamiya thinner is basically Isopropyl Alcohol with an acrylic retarder added. If you are using straight Isopropyl, it can dry very fast indeed. You can buy the retarder at art stores like Michael's.
So long folks!
Posted by gjek on Thursday, July 19, 2007 9:18 PM
   I agree with what was said. I would add that if you use retarder, try adding a drop to your cup, mix well and try it out. Don't just pour some in and go with it. Try adding small increments until your happy with the finish and drying time.
Msgt USMC Ret M48, M60A1, M1A1
