Gravity Feed Airbrush
    March 2005
Posted by gpal on Saturday, July 21, 2007 8:49 AM
Hello,
I am new to the airbrush world and after using my Badger 200NH siphon feed on a few models now I am learning that you can waste a lot paint when you want to spray something small but still have to fill the bottle up over the siphon tube for it to work. Do the gravity feed airbrushes for the the small jobs save paint compared to the siphon feed ? If so ,would the Badger 200G Fine or the Badger 100G be a good brush for this purpose and other fine detailing that requires very little paint? I would still use the Badger 200NH for the larger areas to paint.
Thank You, George
    May 2005
Posted by Bgrigg on Saturday, July 21, 2007 9:11 AM
Yes, gravity fed brushes waste less paint. Try this before you buy a second AB. Turn your 200NH upside down and drip some paint into the siphon tube. Voila, you have teeny tiny gravity fed AB!
It will be a bit tricky using the AB that way, but a single action will be easier than a dual action.
And yes, either the 200G or 100G are excellent brushes at fine details.
So long folks!
Posted by ABARNE on Saturday, July 21, 2007 12:57 PM
George, another thing to try is the get a color cup which can paint with a lot less paint than a bottle.  Using a color cup instead of a bottle, I can put as few as ten drops of paint into the bottom of the cup, thin it, and the AB will paint just fine.
Andy
Posted by nzgunnie on Saturday, July 21, 2007 11:31 PM
I've just got an Iwata C-Plus and compared to my badger 150 I have myself using way less paint.
Posted by MikeV on Sunday, July 22, 2007 6:46 PM
Yes the Iwata would use less as it is a micro-tip airbrush whereas the Badger 150 is a cone tip airbrush. The Badger 100 series would be in the same category as the Iwata HP-C, etc.
Posted by ABARNE on Monday, July 23, 2007 2:44 PM
Actually the Badger 150 and 100 series share the same head, and aside from the paint feed are identical air brushes.  Are you thinking of the Anthem 155?
    May 2005
Posted by Bgrigg on Monday, July 23, 2007 4:30 PM
Oooh, Burn! Mike must have been half asleep when he made his post! Zzz [zzz]
The 100 series (SG, G, LG, SF), the 150 and the 200 series (SG, G & 20) are all the same tip, head, and needle, with the 100 & 150 being dual action and the 200 being single action. The 200-20 has the PPS paint adjustment system, as well.
The 200NH which shares the same two angle cone head assembly of the 155 Anthem.
So long folks!
Posted by MikeV on Monday, July 23, 2007 7:40 PM
Oops! Too many beers last night, my bad! Laugh [(-D] Blush [:I]
The Badger 150 is a siphon-feed though so of course the Iwata gravity-feed mentioned will use less paint.
