I give up with Dullcote!- Answers please
Ant
    July 2007
Posted by Ant on Sunday, July 22, 2007 7:39 PM
i have only recently got back into model aircraft and am trying to be as proffessional as i can. i havent lost too many of the skills i had years ago, however im new to using Dullcote.
i have built 4 planes and 1 1/350 ship.all turned out great with the exception that all have after a few days broken out in white patches after Dullcoating.!!! i have read and re-read this forum for answers but to no avail. so what follow's is what i do and if im doing something wrong please explain.
i let the model dry for a min of 24 hours
i thin the lacquer 3:1 with lacquer thinner. brought from an auto paintshop
i spray at 15-20 psi using about 3 light coats.
i work in a room in my home that is generally not too humid.
the only thing i do that i can think may have an effect is i have a reverse cycle heater and of a night i have it on, could this be causing humidity.?
am i thinning incorrectly? am i using the right thinner? too many/too thick coats?
last but not least how do i fix the white patch's? i have tried recoating, tried spraying a little thinner on. someone said to respray the area's and re-coat.
P.S i have also found that even weeks later if i touch the model with bare hands, after about 10 minutes there is a white patch! i assume this is a reaction to the oil/sweat on my hands
thanks guys.
    September 2004
Posted by giobosco on Monday, July 23, 2007 6:30 AM
Hi Ant, I have to say I had some bad experiences using automotive products on my models. It looks like there is some sort of reaction/incompatibility with the paints you are using. I am not too sure about the humidity factor if that has some adverse effects.  I can only say that when I am ready for the matt coat, I usually spray directly from the can (Testors or Tamiya).  I submerge the can in some hot water for a smoother flow.
Not sure what is going wrong there, how's your preparation?, What type of paint do you use?, Maybe try to use Acrylics.  Before you apply the decals, give the model a good wash in soapy water and let it dry, ensure that no streaks are left.  Then give it a good coat of clear varnish, I don't use future, it takes too long to dry (only use it on canopies).  Apply decals/setting solution, when dry, wipe model again to remove traces of setting solution, give another coat of clear and then matt it with the above.  I succesfully used tamyia/hobby color acrylics with testors dullcoat from the can, no fuss at all.  Hope this helps you and don't get dispondent, I too, had similar troubles just at the end and felt like blasting my model with a sledge hammer.
best to all
gb
Ant
    July 2007
Posted by Ant on Monday, July 23, 2007 7:59 AM
thanks for your help GB. what thinner should i use? i have been told that White Spirit is ok. i normally use Turps to thin my enamals and have had no drama. the next A/C i m working on im going to try a very very light coat of Dullcote and see how i go.
Posted by grandadjohn on Monday, July 23, 2007 10:12 AM
Humidity is most likely your problem. Try using the can or put a moisture trap on your AB
Ant
    July 2007
Posted by Ant on Monday, July 23, 2007 10:33 AM
i have a moisture trap on the compressor. if it is humidity, it must be when i have the heater on of a night.
Posted by ABARNE on Monday, July 23, 2007 2:06 PM
Very weird.  Although I haven't used Dullcoat for a long time, I never expereinced the problems you have described.
The number of coats, within reason, should be irrelevant.  I have some kits that I weathered with artists' pastels that may have nine or ten sealing coats, and look fine.
I don't really thin to any specified ratio, but just add thinner until the paint "looks right" and more importantly sprays right.  At the air pressure you are spraying with, if the DullCoat sprays nicely, it seems like it must be thinned adequately.
Difficult to say.  I used inexpensive Kleen Strip Lacquer Thinner that I bought from HomeDepot and it works fine.  I don't know how that would compare to the stuff you bought at the auto supply.
The thing that jumps out at me as being really strange is that a white patch will form where you touch a model that was DullCoated weeks previously.  I always could handle my models within an hour or two, and have no trouble.  I do have a couple of A/C models that were handled extensively not only during weathering with pastels, but afterwards as they moved to various display areas throughout my house, and after several years, no white spots have appeared.
All of that is making me wonder if your DullCoat either is not curing or is having some sort of a strange reaction to to the thinner you are using.
    July 2003
Posted by saltydog on Monday, July 23, 2007 4:57 PM
to fix the white patches, you could probably apply a nice coat of future floor polish.  the future i use dries in about 10 minutes, if this is too slow i can't imagine anything else drying faster.  anyway, i use model master acryl clear flat and have never had a problem with it.  i'm too affraid of lacquer based clear coats.  i thin it with tamiya thinner and apply in a nice wet coat and let dry.  looks good everytime.  i also have used poly scale clear flat, and tamiya clear flat.  i used acrylic matte coats over mm enamels as well as acrylics.  works everytime.  i'd can the dullcote if i were you and get an acrylic matte product.  later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    September 2004
Posted by giobosco on Monday, July 23, 2007 11:32 PM
Hi Ant,
Well, If I use tamiya/hobbymaster acrylics I usually use tamiya thinner for oil based paints I use the testors/model master thinners.  If humidity is high, you should see some moisture in the water trap of your a/b.  I use CO2 as propellant from a cylinder, bit of a conundrum this one...
all the best
gb
Ant
    July 2007
Posted by Ant on Tuesday, July 24, 2007 11:43 PM
i think i may have found at least one problem. it would seem that the whitning is only on area's i have touched prior to the dullcotting. i noticed this on the ship i built. after a few days the white area's were pretty much where my fingers would be. i think a wash in warm soapy water before dullcotting might be the go!!!
Posted by MikeV on Wednesday, July 25, 2007 10:34 AM
Ant,
Give Model Master Acryl flat or Poly Scale clear flat a try, they are much better IMHO.
