Rust-Oleum on styrene?
    April 2007
Posted by crazygerman on Tuesday, July 31, 2007 5:48 PM
I'm almost ready to paint my T-34 ARV for the Kursk GB, and I happen to have a can of Rust-Oleum that looks about right for the shade of green I need...I don't have an airbrush yet...so I was wondering if it would work on styrene and would it be compatable with enamel clearcoats and oil washes?
“It’s the unconquerable soul of man, not the nature of the weapon he uses, that insures victory.” -George S Patton Jr. On the Bench; 71 "Cuda
    January 2003
Posted by Triarius on Tuesday, July 31, 2007 6:07 PM
Yes, it will work on styrene, and it is essentially compatible with enamels and oil washes. However…Rustoleum in a spray can is formulated to produce a very thick coating so that it can be sanded to produce a very smooth final finish when topcoated. It will obscure fine detail. I have a test piece of styrene that I coated with gray Rustoleum primer to test clear coats. I then sanded it to various degrees: 400, 600, 800, 1000, 1500, and 2000 grits. I never sanded through to the plastic, and I removed a lot of paint.
    April 2007
Posted by crazygerman on Tuesday, July 31, 2007 6:13 PM
Thanks Triarius Bow [bow]...i think in that case i'll try to find a good match from MM. I did a lot of scratchbuilding and would hate to cover it in a thick mess of paint
