from the can
from the can
Posted by Anonymous on Saturday, August 4, 2007 12:32 PM
Hi everyone:  this sounds stupid but hope to hear from some of guys - I just started to get into the hobby and some of the finished products that most of you have done look fantasic.  my questions is have any of you sprayed painted you planes right from the spay can such as MM spray paints (water base) and what was the outcome.  I don't have a compressor or an airbrush.  I'm retired and in my early 70's but I hurting for space.  my equipment thus far is a box, and a lazy susan which I will use outside on a day that is not windy.  Any and all suggestons are most welcome.    Thanks for your input.   Les
    May 2003
Posted by DrewH on Saturday, August 4, 2007 1:39 PM
Hi Les and Welcome to the forumsSign - Welcome [#welcome]
It's not stupid. It's how most everyone gets into the hobby. They are the most readily available and easiest means of painting a model.
I have not done that for a number of years, but it can be done with great results. First, you should wash the model with an old toothbrush and a few drops of dish soap in a sink full of warm water. That will get rid of any grease that is used to remove the plastic from the molds during manufacturing. Let it air dry for a few hours then you are ready to assemble and paint.
Before you start painting, place the spray can in a bowl 1/2 full of very warm water. This will warm the paint in the can and allow it to flow and mist itself on better. Use light coats building up the color gradually. Light colors - such as white- may take 3-4 coats to cover completely. Using the box is a good idea, after your finished painting, place it over top of your work or a cover to the front to keep dust and other nasties off the wet paint. Try to wait a half hour in between coats or 3-4 days. The paint likes to be cured or not started to cure - different from dry to the touch- to have more coats added.
Take your time and you should have some planes you are very happy with. Let us know how it all works out. -Drew
Take this plastic and model it!
