Painting Canopies
Ant
    July 2007
Painting Canopies
Posted by Ant on Sunday, August 5, 2007 9:48 PM
hi all, i like to hand paint my canopies but i always have the same drama. when i apply the paint it doesnt seem to adhere to the clear plastic i have to go over and over it, and when i do recoat its like as if it removes the previous layer. then i get lumps in it.  HELP!
    October 2005
Posted by tabascojunkie on Sunday, August 5, 2007 11:48 PM
Are you waiting until the previous layer is dry? If you paint on top of a wet layer it can pull up the one under it. Tamiyas seem to be really bad about this the little bit of brush painting I've done with them.
Bruce
    August 2006
Posted by OhOh on Monday, August 6, 2007 4:53 AM
Make sure you're giving enough time between coats.
If you're still finding that the paint is lifting and if you're confident that your masking tape can take the abuse try, very lightly, sanding the canopy framing to give the paint something to key to.  It really only needs the frame line to be slightly scuffed.    If you're not keen on sanding over tape use the edge of a new modelling knife - it gives a bit better control.
Good luck, (I hate canopies too!)
    January 2007
Posted by Gigatron on Monday, August 6, 2007 8:53 AM
Your first problem is no primer.  Without a primer base, your paint has nothing to bite to.
The clear plastic is a high gloss surface.  Primer acts as rough surface giving the top paint coats something to grab on to.  Since there's no primer base, the paint will just peel up everytime you paint over it.
There are a few things you can do.  If you're going paint a layer to appear on the inside to replicate the interior color, use a flat color to do it.  First, get a sanding stick with a very fine grit, like a polishing stick for fingernails.  Buff the frame so that's a very slight haze.  The rough texture will be enough to allow the paint to grip.  Then paint the interior.  Let that dry for at 48 hours.  Then you can brush on your top gloss, exterior color.  If you're not doing an interior color, brush on some Mr. Surfacer 1000, let that dry overnight or longer, then brush on your top coat.
After that's all done, you can seal it in with a quick dip in future.
-Fred
    May 2005
Posted by Bgrigg on Monday, August 6, 2007 9:47 AM
Just dip your canopy in Future first, let cure for 48 hours and mask and paint. You will have no problems. If you find a run or drip in the first Future coat, soak in Windex or Simple Green and do it over. Future is nothing more than an acrylic finish and once cured will give the paint a surface to bite into, just like Fred said!
So long folks!
