A new needle lube?!
    February 2005
A new needle lube?!
Posted by RadMax8 on Thursday, August 16, 2007 12:25 AM
Hello, folks. I just wanted to share a little tip with you about airbrush needle lube. After searching my house high and low for any vaseline, I decided on something else. Vitamin E capsules. Yes the same Vitamin E that keeps your hair from jumping off your head, and makes your skin softer (for the ladies of courseWink [;)]) and helps heal scabs from all those exacto cuts acts as a very fine lube. I just thought I'd throw that out there!
    April 2005
Posted by T_Terrific on Friday, August 17, 2007 9:57 AM
Actually, mineral oil will do the same thing, and it is a lot cheaper.
Tom Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    May 2005
Posted by Bgrigg on Friday, August 17, 2007 10:46 AM
Vitamin E capsule use Glycerin for the 'carrier', and needle lube is Glycerin, so it should work fine. I don't know about the States, but we can buy Glycerin at drug stores and it's way cheaper than the little bottles Badger and Medea sell. Mind you I found that out after buying the expensive stuff. I figure the bottle will last me about ten years, so it's really not that expensive.
I have to disagree with Tom, as I use acrylics and mineral oil would only contaminate the paint. I'll stick to glycerin based lubes.
So long folks!
    April 2005
Posted by T_Terrific on Friday, August 17, 2007 11:42 AM
Depends on how much you use for the needle, Griggsey.
I simply wipe the untapered portion of the needle that fits into the trigger mechanism with a moistened cloth, which only leaves a film, which I have had no contamination problems with.
I do not ever recommend flowing any sort of lubricant into an airbrush, especially the front portion of the needle that sees the paint mixture.
However, of course glycerin is better when dealing with water-based anything, provided the whales they kill to get it from don't mind. Wink [;)]
Tom Cowboy [C):-)]
Tom TCowboy
    May 2005
Posted by Bgrigg on Friday, August 17, 2007 12:05 PM
I put it on the tapered part of the needle as well, to help prevent "tip dry" which is a common problem with acrylic paints. So far, no problems. I don't expect any, since Glycerin is used in the production of acrylic retarders.
While you can process Glycerin from whale blubber, most comes from the leftover fats from the meat processing industry, and also from plant emollients, and is mostly corn in origin.
So long folks!
Posted by MikeV on Saturday, August 18, 2007 1:14 AM
Just buy a bottle of Badger Needle Juice and stop being so cheap! Laugh [(-D]Mischief [:-,]
    February 2005
Posted by RadMax8 on Saturday, August 18, 2007 10:14 AM
Glad this topic finally sparked some conversation!!!
Tom, Vitamin E's not too expensive for me because my dad takes it every day. It helps with his eczema and keeps his hair in! So it's win-win! lol
Mike, I'm not cheap, I'm frugal!!! Actually, I can't find any Needle Juice around here. Oh well, mine works wellTongue [:P]
    August 2004
Posted by Tankmaster7 on Saturday, August 18, 2007 10:16 PM
Yeah the regdab stuff works great. Really helps the tip dry on acrylics. (at least when I'm not too lazy to put it on...)
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by MikeV on Sunday, August 19, 2007 9:20 PM
Order some online. A bottle will last you for years. Smile,Wink, & Grin [swg]
    February 2005
Posted by RadMax8 on Sunday, August 19, 2007 9:39 PM
Mike, do you get kickbacks from Badger? lol
Posted by MikeV on Sunday, August 19, 2007 10:02 PM
No I do not. I am an art consultant for them but there is no monetary rewards for me, I just push what I think is a good product and Badger is excellent. Smile,Wink, & Grin [swg]
    February 2005
Posted by RadMax8 on Sunday, August 19, 2007 10:05 PM
I gotcha! That must be a pretty neat job. Is it full-time or on the side?
Posted by MikeV on Monday, August 20, 2007 1:12 AM
It's not a job at all. I like Badger products and I contacted them about it and they thought my knowledge of airbrushing for modeling was good and asked if I would mind telling people about Badger products on here and I agreed. Ken Schlotfeldt is a good friend of mine and I enjoy telling others about the great airbrushes his company produces. You can't buy me as I am a man of integrity and if I did not believe in Badger Airbushes I would not brag about them so much.
    February 2005
Posted by RadMax8 on Monday, August 20, 2007 8:16 AM
Mike , by no means am I questioning your integrety, just judging by your posts on this forum I know you are a man of your word! I may need your help in the next month or so, as i'm eyeballing a new airbrush, and i'd like to hear the pros and cons of it. Since it's a badger, you seem to be the go-to guySmile [:)]
Posted by MikeV on Monday, August 20, 2007 10:29 AM
I will help if I can my friend. Smile,Wink, & Grin [swg]
I know you weren't questioning my integrity, I was just trying to convey my position without sounding like a Badger paid employee. Laugh [(-D]
I see you are a Blue Jackets fan. I have been a Flyers fan since I was a kid although I don't watch many games anymore. I used to go to the Oakland Seals games here when I was a kid......I miss those days!
    August 2007
Posted by ben1227 on Thursday, August 23, 2007 3:42 PM
I agree with mike lol...just go buy the badger regdab stuff...save the whales! Approve [^]
.:On the Bench:. Tamiya 1/72 M6A1-K
