I thought I replied to this last nite, guess I was sleepier than I thought...
As for the original question, I like PlastiKote Touch Up Primer that some auto parts stores and some WalMarts sell in 1oz bottles. It's lacquer, light grey, and lays down very nicely. I thin it about 50/50 or sometimes a touch more with inexpensive, medium temp thinner that I buy at WalMart. Same as finger nail polishes but that's a different subject. And while it clings tenaciously to the plastic, if you do have to strip the model for whatever reason, it barely leaves a trace behind. You can hardly even tell the kit's been painted.
However, while it isn't really expensive, $2.99 per 1oz bottle around here, very soon I'm going to break down and buy a quart of automotive primer. Not sure which one yet.
I have a bunch of spray cans of different primers that I use from time to time but with all the overspray they waste the filters in my paint booth very quickly so I don't use them very often. Some of them are very hard on the plastic too. One other thing about primers, if you're working on a kit that's molded in color you'll want to prime, then use a primer sealer over that to keep the plastic color from bleeding through to the topcoat.
Maddafinga, if you haven't already, go to www.alclad2.com and read their directions for using their paints. They have some good tips. Tamiya paints are one of their recommendations for a base coat. If you want to use them they should work just fine but they are considerably more expensive than the Krylon paints mentioned. Any acrylic lacquer paint would work as a base except with the Alclad Chrome, you need to use an enamel base for that.
Using different color basecoats with most any paint will affect the color of the topcoat. If you do want to try the Metalizer paints as a basecoat I think you'll need to seal them. Otherwise you'll have a layer of what is basically very fine metal dust and there may be a reaction with the Alclad which is basically the same thing I think. Take an old body or another piece of scrap and experiment.
No need for shame...
One other thing, when I tried the link to Alclad I first got their site and then was transferred to some other site. Someone maybe hijacking their link. When I tried again it was unavailable. The site is there though.
