Sanding for a smooth painted finish?
Posted by Anonymous on Tuesday, August 21, 2007 4:27 PM
Hello, I'm new to the site. I just got back into model building after a very long time. I pretty much know allot but can always use new methods and ideas to improve. But anyway I just started a Italeri 1:17 scale destert hawk. I am using Testors Model Master spray enamel and I sprayed the cabin parts gray. It came out with great coverage but not perfectly smooth. My question is should I sand it for a smooth flat finish and what grit sandpaper do you I need. I am sure this will apply to when I paint the actual helicopter as well as future kits as well.  I have the Testors sanding sheets. Not sure what color to use. Thanks.
    April 2005
Posted by T_Terrific on Wednesday, August 22, 2007 3:59 PM
Wet sanding with the finest grit you have is conventional between spray enamel coats.
Tom Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
