Older model 200 Badger
Posted by Anonymous on Wednesday, August 22, 2007 11:57 PM
I'm pretty sure I had this AB in junior high school - would have been around 1969 or so.  The head/tip assembly has been replaced, and I"m thinking the short regulator on the new 200-20 detail airbrush looks a lot closer to the original, might have to pick one up.  Badger rebuilt it for me a few years back, included the new head/tip assembly.  Still works like a champ!  Note the screw-on bottle.  I found a couple of "old style" screw on lids from Badger, only they're for the 33mm bottles, and the original (which I still have, only it's pretty well used..) was for the 28mm bottles.  Wish I could find a jar adapter like the original.
 When did Badger start making airbrushes?  Aren't they fairly recent when compared to Paasche, and Thayer & Chandler?
Posted by ABARNE on Thursday, August 23, 2007 1:39 PM
http://www.airbrushmuseum.com/airbrush_history_timeline.htm
Cool airbrush.  According to the Airbrush Musuem, Thayer & Chandler started in 1891 follewed in 1904 by Paasche.  Badger started in 1963 and in 2000 bought Thayer & Chandler who had closed up two years previously in 1998.
    May 2005
Posted by Bgrigg on Thursday, August 23, 2007 1:48 PM
Cool old airbrush!
That's definitely the "new" 100 series head with the "crown" spray regulator. That should be easily replaced with the "flat" regulator from the 200-20 (Badger PN 50-0370, Dixie Art PN 9950-0370 (at least it should be, Dixie Art add the prefix 99 to the Badger numbers) or Bear Air PN 111558).
When I get home tonight I'll see if that works.
So long folks!
Posted by Anonymous on Thursday, August 23, 2007 2:38 PM
I painted a lot of model rockets and a few model cars with that airbrush back in the late 60's - early 70's.
My dad had fixed me up with a compressor from an old freezer, and an air tank made from a freon bottle.  The freezer compressor has long since died, but i dug out the freon bottle / regulator a few days back.  Right now it's in my basement with a Badger 180-11 compressor hooked to it.  Pretty quiet, and works like a champ.   I am going to set it up with a new regulator, more suited to airbrush use.  The current regulator is intended to be used at higher pressures, has a 160 PSI gauge on it.  I've got a little Norgren unit, intended for 5-50 PSI with a 60 PSI gauge that makes more sense.
    May 2005
Posted by Bgrigg on Thursday, August 23, 2007 8:43 PM
If you've already got the regulator, then go ahead and swap it out. I use an el cheapo $10 unit that goes to 160psi. I only use 10-20% of the gauge, but good enough for my work.
I swapped out the spray regulators with no problem whatsoever. The part numbers I listed above will get you the right part!
So long folks!
Posted by Anonymous on Thursday, August 23, 2007 9:50 PM
I've already got the regulator, it was my Dad's.  I think he got it along with the 180-11 compressor, probably from tower hobbies.  Most likely the one Badger sells.
It did my heart good to dig out that old freon bottle tank and hook it up - Dad made that for me probably 35 years ago if not more.  :)
