Starting to understand the finishing process (I think)
    August 2007
Posted by Rich.Carpenter on Monday, August 27, 2007 2:13 PM
I've been struggling a bit trying to understand exactly what my process needs to be to get the best results possible with my finishing. I use acrylics (for now - not savy enough yet to know if that's best for me or not), and I've come to the following conclusions. Someone please correct me where I'm either wrong or where there may be a better solution. I should also mention that this list was compiled with armor subjects in mind:
  1. I will spray at least one coat of primer when possible before painting.
  2. Acryls can often be sprayed without thinning.
  3. Where thinning is required/desired, I will use actual acrylic thinner.
  4. Cleaning acrylic paint from brushes/airbrush will be done using 91% isopropyl alcohol.
  5. After complete base color has cured, I will apply a Future clear coat to prepare for any decals.
  6. If decals are applied, I will use decal setting solution on the surface of the model first and also on the surface of the decal once it's positioned. After the decals have set, I will again apply a coat of Future.
  7. Any oil washes will be performed using artist's oils thinned approx. 90-95% with mineral spirits.
  8. Brushes used for oil washes will be cleaned with mineral spirits.
  9. Pigments and any other drybrushing will then be applied as desired for weathering.
  10. A final flat acrylic clear coat will be applied. (thinning required?)
One question, where would "filters" (if used)fall in that order of operations, or would that be interchangeable with the oil wash?
Rich Currently my bench: Academy 1/35 Tiger I Early (30%), Hasegawa 1/48 Spitfire Mk. Vb (25%), Italeri 1/35 Demag D7 with Flak 38 (30%)
    August 2007
Posted by Rich.Carpenter on Tuesday, August 28, 2007 12:49 PM
A lot of views, but no comments. Am I to take that to mean that I have it mostly correct? This just cannot be. Tongue [:P]
    October 2006
Posted by Mist086 on Tuesday, August 28, 2007 12:59 PM
I always clean my brushes and airbrush when using acryls with windex or windshield fluid.  other than that you got it down pretty much
    May 2005
Posted by Bgrigg on Tuesday, August 28, 2007 1:25 PM
Here are my comments:
  1. I typically don't use primers, but I do make sure that the mold release agents are washed off the surface and I give the styrene a final wipe with Isopropyl Alcohol before painting. I DO use primers when painting light colors on dark colored styrene, and also paint aircraft fuselages with Tamiya AS-12 Aircraft Silver which works much like a primer. I do that with the idea that any scratches will show the "natural" color of the fuselage.
  2. "Some" acrylic paints don't require thinning, but it most cases they still benefit from thinning, even if it's very minor.
  3. Using appropriate thinner is very good. Tamiya can be thinned with Isopropyl Alcohol, which in turn can benefit with the addition of acrylic retarder. I tend to stick with their thinner.
  4. I use Windex with Ammonia. Actually I use Zep brand Concentrate with Ammonia, which apparently is no longer sold. That came in a gallon jug and makes enough for 30 gallons! It will likely last me years! They do make a Refill window cleaner with Ammonia, which is less than half the price the Windex brand refill sells for. It's considerably cheaper than using Isopropyl!
  5. No comment required.
  6. Careful with this, some decal solutions are vinegar based. Vinegar's key ingrediant is Acetic Acid which can attack the Future coat and cause hazing. Sometimes it doesn't, and sometimes it does. For this reason I use only Micro-Set and not Micro-Sol.
  7. No Comment required.
  8. No Comment required.
  9. No Comment required.
  10. I've only used Future mixed with Tamiya Flat Base, and haven't required any thinning thus far.
So long folks!
    August 2007
Posted by Rich.Carpenter on Tuesday, August 28, 2007 3:20 PM
Thanks all. Couple of questions:
Just curious, is it still necessary to wash the surfaces if I intend to use primer? Granted, I'm sure that it would be the optimum approach, but washing just adds one more opportunity for me to stag small parts and rip them off the model with the wash cloth.
Duely noted. The acrylic retarder may be a good idea for me as well, as it would help me get better coverage over and around small detailed parts/areas without overapplying.
Any cheap window cleaner with ammonia. Got it.
I purchased the Micro-set solution, so I should be ok here. It really was a toss-up for be between the two, not having seen any significant difference between the two from what I had read (more than one person had mentioned that they could be used interchangeably), but I just finally decided that a "SETting" solution seemed more appropriate for my needs than a "SOLution" solution. Wink [;)]
Thanks for the feedback!
    August 2007
Posted by Rich.Carpenter on Tuesday, August 28, 2007 3:23 PM
Does the typical windshield washer fluid contain ammonia, or do you not worry so much about there being any ammonia in your brush cleaning solution? I know windshield washer fluid is really inexpensive and would be a good alternative to Windex and Isopropyl alcohol.
Posted by espins1 on Tuesday, August 28, 2007 3:40 PM
The key to cleaning brushes and airbrushes when you're using Acrylics is the amonia.  Amonia will break down and disolve acrylic paint faster, easier, cheaper and safer than anything else.
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
